Took the shit box out with other shit boxes. Smashed the limiter again in 2nd a few times, I still haz PS belt.
Great success.
  • Like 6
1 hour ago, admS15 said:
No need for an M3 anymore then... Did you chop the Evo?
Evo chopped itself, exhaust manifold cracked.
NA 4G63T lol..
Nah, would still take a F80 LCI M3 if someone is retarded enough to swap.
  • Sad 1
1 hour ago, r32-25t said:
Evo3!! so pretty
He will be at All Jap Day too!
Just needs his manifold fixed before then.
  • Like 1
2 minutes ago, r32-25t said:
At the moment I still don’t have a running car and it’s like 14 weeks away
You're nearly done, what are you on about?
Made a temporary, maybe temporary permanent heatshield for the ABS pump, loom wiring.
Should stop things melting on the circuit after a few laps.
It's a bit ugly, but better than a pile of molten wiring at the track.
If money permits, might use those Real Thermal guys and wrap the gate, housing and dump.
  • Like 3
I'm surprised you think it looks ugly, I think it looks great.
I'm not sure if this would effect how well it works, but painting it black might help it blend in with the background if that's what you'd prefer.
Thanks mate, I might try hitting it with engine enamel black.
Might make blend in a bit more.
Test and Learn tonight, pray to all the 33 gods out there, and the Skyline gods nothing breaks or fails.
  • Like 2
It's alright, good to use the car instead of looking at it.
Will upload my PB lap soon, just trying to see why I can't get any of the telemetry from the VIRB. Probs dropped it a few too many times lol.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
