Took the shit box out with other shit boxes. Smashed the limiter again in 2nd a few times, I still haz PS belt.
Great success.
  • Like 6
1 hour ago, admS15 said:
No need for an M3 anymore then... Did you chop the Evo?
Evo chopped itself, exhaust manifold cracked.
NA 4G63T lol..
Nah, would still take a F80 LCI M3 if someone is retarded enough to swap.
  • Sad 1
1 hour ago, r32-25t said:
Evo3!! so pretty
He will be at All Jap Day too!
Just needs his manifold fixed before then.
  • Like 1
2 minutes ago, r32-25t said:
At the moment I still don’t have a running car and it’s like 14 weeks away
You're nearly done, what are you on about?
Made a temporary, maybe temporary permanent heatshield for the ABS pump, loom wiring.
Should stop things melting on the circuit after a few laps.
It's a bit ugly, but better than a pile of molten wiring at the track.
If money permits, might use those Real Thermal guys and wrap the gate, housing and dump.
  • Like 3
I'm surprised you think it looks ugly, I think it looks great.
I'm not sure if this would effect how well it works, but painting it black might help it blend in with the background if that's what you'd prefer.
Thanks mate, I might try hitting it with engine enamel black.
Might make blend in a bit more.
Test and Learn tonight, pray to all the 33 gods out there, and the Skyline gods nothing breaks or fails.
  • Like 2
It's alright, good to use the car instead of looking at it.
Will upload my PB lap soon, just trying to see why I can't get any of the telemetry from the VIRB. Probs dropped it a few too many times lol.
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
