2 hours ago, ActionDan said:
Also what rice body kit bits can we add to the missus Tiguan to make it look less mum spec?
Maxton Designs do small lips and stuff that might suit your aesthetic needs.
Not sure if you got the PFL or FL MK2, just have a look here:
https://www.ausbodyworks.com.au/collections/tiguan
  • Like 1
Oh wow, these actually look quite nice. Might be a bit too subtle and still look mum spec though in my opinion.
What about wheels? I saw a Golf wagon the other day with some fancy rotiforms on it. Very unexpected and it looked great as they transformed the look of the whole car. Though depending on how the car is driven it may result in anguish having them murdered on curbs.
The 20s ride ok, just not with the Continental Contact Sport 5 it comes with. I've replaced them with Pirelli Scorpion Verde and it rides much better, albeit lost cornering grip and straight line traction.
I can blaze the front tyre(s) when I mash the pedal before the Haldex kicks in.
7 hours ago, Dose Pipe Sutututu said:
Won't gutter the wheels as easily too
The country doesn't have gutters. Just huge ditches on the side of the road... 😛
  • Haha 2
I went to a CFA call out, during that wet AF winter, thought I'll put my car off the side of the road to clear the way, woops, too far, dropped in up to the sill on the passenger side immediately, did call out, had a few goes at getting it out (had just switched back to road tyres, no good lol).
Chucked my rear hitch receiver onto the DELP guys car and used my winch to pull the noise back out onto the road lol
Scratched my rims too :(
So yeah, I love those ditches!
  • Sad 1
Sound deadening some more, repaired the OEM mat between the rear seat and boot, covered its mum in sound deadening too.
New Maxi Cosi Titan Pro seat in too, got it for $299 on sale with 2% cash back via Cash Rewards. Brings it down to $293!
  • Like 3
They did ok, when compared to Toyota. Ever seen a Chaser?
Btw.. my sound deadening efforts was worth it. Cabin noise has dropped, once I do the front doors and the roof lining it's going to be 0.01% less shit overall.
  • Like 2
  • Haha 3
1 hour ago, ActionDan said:
Man, R33 interior is iconic to me, mad memories.
The rear floor mats.
Even to this day I reckon are wickedly awesome!
Some days I wish I still had some of that stuff for mine rather than stripped out to be used for track work only. At the time though, someone needed a way to make it less street able so I would keep my license / not die.
The Yaris has the floor mats from my 86
They are the best part of the interior LOL
No more mods, car is done, etc.
So turns out my tiny AF lift pump is still moving enough fuel to pressurise my surge tank and even the fuel rail when both surge pumps are off. I'm getting about 0.55bar of fuel pressure at the rail with the surge pumps off and only the lift pump running.
This means that the OEM venturi/siphon is causing a massive restriction, enough to build that pressure. I've been told it's not too much to be worried about, however the inner efficient Asian that I am says no!
Pressurisation of the surge tank & running the lift pump harder does three things:
  • degrades the surge pumps quicker
  • more load on the electrical system as the surge works harder
  • by product of the above, more heat is generated
  • (possibly point 4) more heat generated means all 3x pumps swim in a warmer fuel soup and degrade faster
So yeah, at some stage I will need to remove that stupid fuel tank lid/hat/cover whatever the fk you want to call it and pop off the OEM venturi/siphon and pop this one on - pretty straight forward really, just massive CBF as I will smell like shit and inhale heaps of petrol in the process.
  • Like 1
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
