4 minutes ago, Dose Pipe Sutututu said:
Sparks...
Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
  • Haha 1
2 hours ago, Dose Pipe Sutututu said:
Farken, it's because all the disrespect from me, it's decided to die.
So you reckon a few sweety something's whispered in her window and she'll behave for me? 😛
  • Haha 1
Lolololol maybe, man I hate this car.
Lapsed judgement a respray and a new motor, when I should have just scrapped the lot when I had the chance.
Farken.
11 hours ago, GTSBoy said:
Actually, I'd argue that that is exactly when having the wastegate/scroll isolation correct would show the most benefit.
Of course it would be - But you shouldn't be here.
Farken.
Hey, it's me!
Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it.
If this is not you, then sell it cheaper. It will sell at a certain price after all.
  • Like 2
6 hours ago, Kinkstaah said:
Hey, it's me!
Like a big hood scoop, and massive whiney boy supercharger?
Think he'll sell it to me at my offer above? I could probably get it to $75 if he needs a little more convincing 😛
5 minutes ago, No Crust Racing said:
15a? Crikey
It was $7 more than the 10A - as an Asian, I see value. Dollar per A lol
5A - $113 - $22.60 per A
10A - $189 - $18.90 per A
15A - $196 - $13.06 per A
Sure the maths stacks up, however does the use case? maybe not - however I wish to purchase a boat in the future.
  • Like 1
So.... here's one for @GTSBoy .....
I plugged up the battery in the boot, to my surprise no sparks, no shorts, alarm went off, dome light on, etc. tried to crank the car, motor rotated a few times. Battery is pretty flat so will need more juice before I try to start it.
With the battery plugged up at the back, when you pop a volt meter across the chassis and the jump point, you get a nice 12V, no issue.
However, when you disconnect the battery at the rear, you straight up get a short.
My broscience is thinking there's some issue with the rectifier, dead diodes perhaps?
Also your meter is showing not a dead short, but a 40ohm resistance if I'm reading that right.
On a 12V load you would be seeing a 300mA constant draw. Enough to kill a battery in a couple of days easily, not enough to cause sparks and things to glow red hot.
It beeped, confirming continuity. If it didn't, no issues.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
