4 minutes ago, Dose Pipe Sutututu said:
Sparks...
Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
  • Haha 1
2 hours ago, Dose Pipe Sutututu said:
Farken, it's because all the disrespect from me, it's decided to die.
So you reckon a few sweety something's whispered in her window and she'll behave for me? 😛
  • Haha 1
Lolololol maybe, man I hate this car.
Lapsed judgement a respray and a new motor, when I should have just scrapped the lot when I had the chance.
Farken.
11 hours ago, GTSBoy said:
Actually, I'd argue that that is exactly when having the wastegate/scroll isolation correct would show the most benefit.
Of course it would be - But you shouldn't be here.
Farken.
Hey, it's me!
Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it.
If this is not you, then sell it cheaper. It will sell at a certain price after all.
  • Like 2
6 hours ago, Kinkstaah said:
Hey, it's me!
Like a big hood scoop, and massive whiney boy supercharger?
Think he'll sell it to me at my offer above? I could probably get it to $75 if he needs a little more convincing 😛
5 minutes ago, No Crust Racing said:
15a? Crikey
It was $7 more than the 10A - as an Asian, I see value. Dollar per A lol
5A - $113 - $22.60 per A
10A - $189 - $18.90 per A
15A - $196 - $13.06 per A
Sure the maths stacks up, however does the use case? maybe not - however I wish to purchase a boat in the future.
  • Like 1
So.... here's one for @GTSBoy .....
I plugged up the battery in the boot, to my surprise no sparks, no shorts, alarm went off, dome light on, etc. tried to crank the car, motor rotated a few times. Battery is pretty flat so will need more juice before I try to start it.
With the battery plugged up at the back, when you pop a volt meter across the chassis and the jump point, you get a nice 12V, no issue.
However, when you disconnect the battery at the rear, you straight up get a short.
My broscience is thinking there's some issue with the rectifier, dead diodes perhaps?
Also your meter is showing not a dead short, but a 40ohm resistance if I'm reading that right.
On a 12V load you would be seeing a 300mA constant draw. Enough to kill a battery in a couple of days easily, not enough to cause sparks and things to glow red hot.
It beeped, confirming continuity. If it didn't, no issues.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
