C34 rear end clicking at slow speed
Hey guys, having some noise from the rear end of my '99 RS4S with LSD (I think its a 2-way), seems to be happening more but the weather here has got really cold lately (a high of around zero C and a low of minus 5 C) so that might be related.
At slow speed, I'm hearing a clicking/snapping/metallic click noise coming from the rear. Sounds to me like it's rear left, but my wife thinks its rear center/left/right. It is not rhythmic as far as I can tell. ie if I'm going along it doesn't happen at a regular interval. Has been happening a bit lately around 40kph and even 60 kph once or twice. I don't notice any movement or jerks/etc, just the noise. Really want to address it if its something wearing out, etc.
Doesn't seem to be tied to bumps in the road surface, so I don't think its the coilovers but who knows. Sounds really similar to a frontend noise that turned out to be the sway bar link, but it's not as predictable with the rocking of the car like that problem was.
In case its related, theres some vibration in the drivetrain from time to time which could be front end but could be rear end related too.
Cheers!
https://www.sau.com.au/forums/topic/468411-c34-rear-end-clicking-at-slow-speed/
clicking in rear site:www.sau.com.au
Copy and paste that into google.
Honestly it could be anything, arms, driveshafts, diff, etc. You'll most likely have to get out some tools and have a poke around, get a big pry bar and put some pressure on all the pivot points on the arms and see if anything moves.
I had a low speed scuff and a click after installing my new Nismo 1.5-way, turned out to be two unrelated issues:
  • Handbrake setup binding
  • Tail shaft counterweight just touching the mid muffler at certain revs, making a clicking noise
Neither issue was diff related but I was super attuned to all noises from the rear after getting the LSD done :)
Thanks guys. Gonna get under it this weekend and do a visual plus moving things to see if I can reproduce. Definitely happening quite a bit today. Doesn't seems to affect driving.
Good plan. Put the rear on stands and run it in 1st gear & listen carefully next to each wheel, that helped me pinpoint some of the issues.
Sounds good thanks @V28VX37 I'm a little sketchy on running it on stands, but as its 4WD, I would need to have it on stands on all 4 corners? I would love to be able to see the drivetrain running. I have a vibration issue I've been trying to eliminate for a while now and the mechanic has told me to take it to a driveline expert. I'd like to have some knowledge going in.
Yep all four corners up for sure since it's 4WD.
I've made small adaptor blocks out of wood to allow jack stands under the sills, at the standard jacking points. This means that the suspension is fully unloaded when on the stands.
There shouldn't be any issues running your car on stands unless there's enough vibration to cause it to jump off, which is pretty unlikely. As a precaution you could have a mate with one hand on the ignition to shut it down in case anything goes astray.
Thanks @Trex and @V28VX37. Those wood blocks sound like a smart idea.
I might put it into 4wd diagnosis mode (pull the green plug in the kickplate) and do the 5 brake pedal stabs to force the car to run in RWD. Will do that and drive a little so that it's definitely doing it before jacking it up.
  • Like 1
Also do the most basic test - put car in neutral and turn wheel by hand when jacked up. If there's increased resistance at a certain spot across the rotation it could be the hand brake assembly, this was one of the issues with mine.
  • Like 1
Be careful, that won't remove all drive from the front wheels in a C34 (or and R33 or R34 for that matter), if you are going to do this you still need 4 wheels off the ground.
I think you might be better to take it to a competant mechanic, they do this sort of stuff all the time without a ferris bueller's day off type ending
  • Like 2
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
