ALL WORK DONE BY Chris @ RACE PACE. SPENT OVER 30K ON MODS + 20K THE CAR ITSELF.
ALL BRAND NEW PARTS.(10,000 KM OLD) CAR IS CURRENTLY IN NSW.
160xxx Genuine KM's.
Car is sounds and feels amazing.
$22K As is.
$20k without The Gloss-Black TE-37'S.
BLACK R34 GTT 268RWKW
HKS GT-RS Turbo ~ 268.3RWKW by Race Pace
Painted Black Blitz Return Flow Intercooler
Kakimoto Regu 06&R Turbo Back Exhaust
Apexi Pod Filter
Kaaz 1.5 Way LSD
High Flow Injectors
Bosch 040 Fuel Pump
Apexi Power FC D-Jetro
Greddy Profec 2 Electronic Boost Controller
Exedy Heavy Duty Cushioned Button Clutch
Z32 Air Flow Meter
Splitfire Coilpacks
BC BR Coilovers
Hicas Lock Bar
Turbosmart Dual Port Blow Off Valve
Nismo Titanium Gear Knob
Dark Tinted Windows
Nismo Clear Side Indicators
Project MU Handbrake Shoes
Project MU NS400 Front Brake Pads
RDA Front Disks
East Bear Body Kit
Viper 3203 2way Alarm
34 GTT Custom Plates
Factory Sunroof
6000K HID Lights
Rolled Guards
Redline Lightweight Shockproof Gearbox Oil
Royal Purple Synthetic Oil 10w-40
Penrite 75w90 LSD Oil with Friction Modifier
Bridgestone RE002 Front Tyres
Volk TE37 Super Laps 17x9 +22 & 18x9.5 +22 (Rear)
Volk Black Duralumin Lock & Nut Set
Pioneer AVH-X5750BT Double Din Head Unit
Alpine SPR-60C Type R Speakers
Alpine SPR-60 Type R Speakers
Alpine PDR-F50 4 Channel Amplifier
Alpine PDR-M65 Mono Block Amplifier
Alpine SWR-12D4 Type R 12" Subwoofer
Edited by richee
https://www.sau.com.au/forums/topic/468472-black-r34-gtt-260rwkw/
12 hours ago, DrNismo said:
when was it built to spent 30k on mods etc to make 260rwkw? i.e know some could have gone body to etc.
more pics please
30k is more than just the power mods
Doesnt take long to work your way up to that sadly!
  • Like 1
2 hours ago, SKY5HW said:
provided the tune is good that power level is no major strain on the engine. Factory internals are pretty good on 25 neos. Yes it can be improved on but for this level of power no need to waste the money
  • 8 months later...
On 1/18/2017 at 7:28 PM, SKY5HW said:
Friend has a 285RWKW GTT with stock engine and has been thrashing it for almost a year, still goes strong.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
