the scalar is interesting.. at 80~90% of ethanol registered it should be 100% of the compensation table, yet you tuna has used 133%
Meaning it would be your base tables + 1.3x of the compensation table applied on top for fuel.
Hopefully the timing table isn't like that, because well... it's an interesting way to tune.
Also 44% more fuel is massive, 133% of 44% more fuel is obscene. The numbers just look... wrong?
The stoich values of 98 and E85 are too different surely for both the 98 tune and E85 tune to be right at the higher end of that scale. Either the 98 base tune is dangerously, dangerously lean, or the E85 is horrifically rich.
Now keep in mind, if you have the O2 sensor running and the controller doing its thing, it is possible for these correction maps to be really far out, and the O2 controller will do what it can to adjust. This may be the reason the car has bad E85 economy if it cannot actually trim enough up top. What is your AFR under load on E85 anyhow, what does the Haltech say/does it show in the onboard logs?
Not sure without going doing specific diagnostic runs.
I've got a mate coming over tomorrow who will want to go for a spin so can take the laptop and upload a trace then.
That said i think we established that my economy was about the same as others here.
I have a trace from winton but the car had a phat boost leak.
Just spoke to another local tuner and showed him those snaps and he said the same thing about it being unusual but could be fine depending on the rest of the setup.
He's happy to have a look at my log after I get one.
Will go from there.
It's interesting to say at the very least, I personally don't tune like that.
I'll provide screen shots of a S15 I did about 2 months ago with a halaltech when I'm home.  I personally did not follow the same approach as your tuna.
  • Like 1
They call me the postman, because I always deliver...
https://expirebox.com/download/a700385dce0e228b3426cb2b28ae741a.html
Diagnostic csv from a quick run down the highway and back today.
Only 2MB, file expires in 48hrs.
"Yeah I floored it and it was like 9 or 10 or something around full boost, or there abouts, yeah between around 4 and 5k rpm"
Would have been heaps accurate and a great way to do some logging lol you muppet
Then you'd be the first person jumping on to say "You should have logged it properly."
You must be a blast at parties lol
What you do care about besides being salty all over SAU lol
I'm confused, why did you and are you still posting in this thread anyway?
It's cool if you like me dude, we can take it to PM ;)
Help? Do you mean asking your thoughts about your Evo? Or talking -9s and response etc? Not sure if I count opinions as "help", but then again you are helping by answering and giving me your thoughts so I guess that's a fair point of view from a certain perspective - if that's what you mean. Come to think of it, you're actually probably more "helpful" and generally less salty in PM.
I like this sort of "help" you provide lol Took about 2minutes and that was only going back through a handful of my own threads and lately. Keep up that helpfulness :D
3.JPG.46928b1c113209be6498bb9b76213992.JPG4.JPG.812c7c3042e17788f4a017b2034049d1.JPGCapture.JPG.3298279ac7dfc783944aadd17364022e.JPGCapture2.JPG.3dfdffa4d5dd4cda41139e6eda8c2a84.JPG
So yeah, I guess maybe that's the way "I" wanna be and nothing to do with you at all lol
Ah well, we'll always have Paris xox
Other than the curvature of the earth, they are kind of all valid points :P
But yes O2 gauge is kind of needed, everything else seems "fine"
If you wanted to get real creative you could measure your VSS against time, to see if you were really slower between two specific points/runs. This however would require the problem to be reproducable at will. Or at least happen while you are logging it.
Note: I didn't see the boost actually hit the limit of what the ECU is seeing at all. MAP pressure was all 21.5ish points, when it goes over the limit it will just flatline at 22.8 or w/e it is. The graphs do not show this.
  • Like 1
Given the context of those comments, not really ;)
Dyno will fix all with new map sensor and cams, then all of this will be a distant memory (also closed loop boost unless there's something I'm missing about wy you'd want to be open loop?).
Still doesn't explain why every comment seems to imply the fuel tables are "odd".
They look "odd" because E85 typically needs "30%" (give or take) more fuel than 98. In the real world its actually a little less.
They also need 30%, all over the rev range. It does differ a little under load (otherwise it would be 30 in every cell!) but not from 19 to 43%.
Yours goes from 19% under low load, to 43% under full load.
In addition to that,  your tables imply that you add 133% of the correction when you have 80% ethanol in the tank.
This would mean it would be 133% of 43%.
20% is too little and your E85 would be dangerously lean.
43% is too much and this means either your E85 map is fine (and your 98 is too lean) or your E85 is too rich.
Note: The above numbers are when 100% of the correction is being applied to a decent base map.
However.... yours is 133% of the numbers applied!.
133% of the correction being applied means that everything is 'out' even further'. The numbers are impossible numbers, it can't be correct, unless something is making it be correct, which is what the O2 WB does, it adds and removes fuel to try and hit the target on the "Target AFR" map, which is basically closed loop fuel control. The Target AFR map doesn't appear to be too bad as it's looking for 12:1 AFR under full load.
It is common/advised practice to have the base map as accurate as possible, and not have an O2 controller have a monstous effect, though the Haltech lets it apply up to 25% more or 25% less fuel if need be. If this fails for any reason you are going to have a bad time if it is set up this way.
  • Like 1
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
