... 1) isn't the answer because Lith asked two different things..
What is controlling boost/map pressure/load when you are driving around on the street?
You can't really tune over what the ECU is seeing, unless you fudge the numbers and have the same timing/fuel at 24psi that you do at 21psi. This is really very bad for both possible boost settings, or it's perfect for one of them, and really bad for the other one.
There is an argument that when it's set to 24psi you are never at 21psi at 7000rpm, or at 21psi at 5000rpm, so you can use those cells on the map to tune for 24psi but.. yeah...
The best way to test this is actual testing, to confirm whether it's in your head or not. Phone app of some sort would be ideal to do a few back to back runs on a deserted (private) road. Especially if it "feels bad". Cars aren't ever truly intermittent.
Those are kind of the answers I expected though to be fair it's hard to know what is definitely going on - I obviously have my suspicions.
I should have asked a 4th question, do you have a separate boost gauge to show you what boost you are actually running?
My experience with tuning on the dyno is that it is really easy to get a consistent boost curve as the conditions will be consistent and the engine will always "pull" through the rpm at exactly the same rate.   Because the car is always following pretty much the same boost curve, it will also seem like the tune is perfectly on point - so it'll seem like you have got away with mystery tuning and getting a solid tune, however that may not be the case in the real world.
The first thing I'll suggest is entirely possible to be going on is that you aren't running the same boost curve on the road as you were on the dyno.  Internal wastegates can be notoriously finicky and often need varying inputs from the ECU/boost control solenoid to be kept on track - this is why we have closed loop boost control and why tuning the base duty cycle tables can sometimes be a fine art, this is particularly the case when you are running a fair bit over gate pressure.  Targetting 24psi when running 1bar actuators would fit well into that category, imho.
The trick here is that the ECU can only see "21psi" so god knows what it thinks it's doing when it's trying to control boost, I have no idea what the tuner would have done with the tables but I can only assume that it's utilising a fixed duty cycle for anything over 21psi to try and maintain "24psi" and there will be no adjustment if it goes over or under 24psi.  This means you could potentially be overshooting or undershooting your 24psi on the road and the ECU will do nothing at all about it, so you have the very real possibility of running mystery boost!
That all by itself could cause a certain amount of what you are talking about, as you have said yourself - it feels like it's running less boost, but wait... there is more....
If the tune "looked fine" at 24psi on the dyno, that means that the timing and fuelling is mint for 24psi.   What this means is that if you end up hitting only 22/23psi then the timing and fuel is retarded and rich for the boost levels you are actually hitting.   But wait, there's still more!   What if you overshoot 24psi?    That could get much more exciting.
What I can guarantee is that the transient areas between 21-24psi will be different in real life than on the dyno, so who knows what has been done to cope with that.   I'm guessing it'll always feel slightly flat in that range before it hits your boost target IF it is actually successfully and consistently hitting the target boost.  I honestly don't want to wager how likely that is.
Just a thought, anyway.
Edited by Lithium
No extra boost guage, not forking out the many dollars to get the Nismo MFD upgrade and don't like additional gauges.
Am sourcing a map sensor now and will go to closed loop when it goes back in for cams and springs.
Appreciate the feedback :)
20 minutes ago, ActionDan said:
Is there anything special about the Haltech sensor that warrants 3x the price of any other universal sensor?
no... and also they already have their scaling determined however it's not rocket science to determine the max and min vs max and min of pressure as the output is linear and not exponential like temperature sensors
Waiting on tuner to give me the price he can get the Haltech one, as he gets better prices.
Otherwise, any issues with this?
http://www.ebay.com.au/itm/151315040163?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Probs just grab the Haltech one n the end, but nothing wrong with having a backup plan.
Noticed one of your posts where you posted a picture on another subject , your still running stock Fuel regulator
an adjustable regulator might be a good idea if your going to run high boost setting.
New when I did the fuel system upgrades, but I have heard that when switching to e85 you should replace it after a few thousand k's as e85 tends to clean the fuel system out of shit.
Can't hurt to grab one as a spare when it goes in.
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
