Cool
My Knock sensor count climbs in hot weather at low rpms and boost is reduced
but when its cool like today count is 0 and boost kicks like a mule and car breaks traction in 1st , 2nd & 3rd.
Interesting topic re: Map sensor. I'm running -9's (GT-SS), on a Vipec. My tuner (DVS Jez) also tuned 'around' the 3 Map sensor. I hit 24psi boost as well from 4-5000rpm before it backs down to 21psi up until 8K redline.
I don't think it's anything new to tune beyond sensors, on the dyno, but I can understand why it's less than ideal.
It was a last minute decision while we were there, but I should have pulled my finger out and bought the proper sensor afterwards.
A 3 bar map sensor will read up to 29psi
  • Like 1
Fair enough. Mabee i was told incorrect info. Someone mentioned to me that 3 bar absolute is not the actual same as total "boost". And just looking up my Vipec, it's 2.5 bar map sensor or 22ps "boost"i?
Could be completely wrong though.
2 hours ago, ActionDan said:
Wouldn't the wideband see it leaning out - and react accordingly?
but how would your wideband determine you've over boosting? or that you're running way to much timing?
And how would your wideband and or your map sensor determine you've over boosted and cut fuel/igniting to your motor?
Pointless having engine protection that's not protecting a basic thing like exceeding load, in this case boost.
  • Like 2
10 hours ago, ActionDan said:
I got you, will put an order in tomorrrow.
Let us know how you get on.  While there is a good chance that it is to do with that, there is no guarantee BUT a MAP sensor that suits what you are doing is really a must have imho so not wasted money no matter what way you cut it.    Obviously it'll need remapping to get rid of the guess work on the 250kpa load range - good luck!
On 3/20/2017 at 6:55 PM, ActionDan said:
Any easy way to test them? Boost leak test doesn't help as any leakage stays in the intake so total pressure remains the same.
My BOV's are plumbed back. Leakage past the BOV just ends up back on the hot side of the motor. Total pressure remains the same and given the noises involved in pressuring the system, hard to hear if the BOV is unseating.
Edited by ActionDan
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
