GKTECH V3 KNUCKLES
G'day lads. At the moment I'm putting together an R32 street/tdori machine and am up to the knuckle part. Let me say I'm a fan of GKTech and the quality/price balance they work with, but on top of that the options for the R chassis are slim, so these seems like the top pick.
I already have Silk Road camber arms set at 35mm shorter than stock, will be running R33 LCA's with a customised flat adjustable lock stop, Strongflex poly bushes and have extended tie rods and non-offset spacers to go in. Will be moving the rack forward 25mm as well. Currently rolling on +30 R33 GTR wheels but will be going to something in the +15 to +20 range soon.
So, the question is - are they worth the extra cost? Obviously they're an upgrade compared to a modded stock knuckle. The unsprung weight advantage sounds great as well as the claimed linear feel, but considering I should be saving for Japan later this year they're hard to justify at something like twice the price of getting some modded locally. Can anyone comment on the driving feel?
https://www.sau.com.au/forums/topic/469718-gktech-v3-knuckles/
I have never personally used them and i actually haven't even heard of anyone using them. The pick of the bunch for modded 32 knuckles is JDI fabrication in melbourne. All the people from vicdrift use them and swear by them.
Next question, why do you need different knuckles? Personally i don't believe they are needed until you are able to outdrive the standard ones and they become the limiting factor.
I can half comment on this I have a r32 gtst and got the V2
I actually just put a pair of these in my car 2 weeks ago and drove on them last night... all be it grip driving but I have drifted for a long time etc and know the difference in feel
1) they are fabbed up really nice, except one thing we noticed immediately was that they obviously got the bearing case machined and then welded all the other bits on etc - great quality except the heat has obviously put the bearing case out of round by the tiniest bit and had hell of a job getting new bearing case in there
2) I cant comment using your suspension arms and ride height etc but we had to do some adjustments to get everything to fit up, I have full tote odds suspension setup etc (everything) and Tein extra length tie rods etc etc ... I ran out of tie rod length so had to get rack extenders. Then running 18 x 9.5 +12 with a 255 semi tyre on it the tyre then hit the upright, we had to space that out 10mm which gave us bees d*ck clearance to the upright - need more, then came trying to make the tyre fit into the guard and wheel well in its new postion. Not uncommon when you change the ride height etc but do bare it in minid that things like this might have to be addressed
3) they have a sh*t load of lock - when I drifted I had some albeit mild 3up cut and shut knuckles from Japan, these had way more lock. You wanna run wheel small thin and really wide to take full advantage of the lock aka: what they do with wisefab
4) they have approx. 20mm drop built into the knuckle - so on a lower car like mine where the arms where just slightly starting to push the correct characteristics geometry it bought it back to spot on and everything looks and works great
I am grip driving now and bought them for the 20mm drop to correct my geometry. Are they good yes, are they a hassle and cause a few probs putting them in - sort of ( I also don't believe many tings are just 100% bolt in so expected some small probs). Are they necessary for you that's a decision only you can make but Id say from my previous drifting experience (did ADGP for 3 years) no you don't absolutely need them and the above mentioned JDI ones that everyone runs will be more than suffice.
My 2c
Edited by bcozican
Topstage composites S14 snapped one of GKtech's front knuckles clean in half at WTAC 2016 (I cant find the photo, but I do have one). Obviously a lot more pressure at high speeds and with Advan semi slicks, but apparently most of GKtechs stuff is made in China. (not saying they make bad quality products, just mentioning for anyone who thinks knuckles at that price range are made in Aus)
Cool, thanks for the info guys. I know they aren't essential but considering the benefits and my like for messing around and upgrading setups it's hard to ignore that they exist. JDI do seem to have a longstanding rep, too, and good pricing, though I was going to give Kays Fab a shot as he seems to do good work and is local so no shipping.
Bit scary that Topstage broke some, but then again shit does and can happen. You'd think that they might spec machining on the bearing case post-weld considering that heat always causes some distortion, but it must be a price point factor. Maybe even some heat treating too, but again would drive the cost up if it's not entirely necessary. GKTech do a lot of FEA testing though so at least there is that going for them.
For now I think I'm going to leave it at non-offset rack spacers, solid rack bushes, solid steering spacer, wind the camber back a degree and if necessary do a bit of grinding on the lock stop on the knuckle. Then move on up from there so I can say I've tried it all from sloppy 26 year old stock to the good stuff.
Cheers to everyone for the help!!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
