Radiator upgrade
Ok so i have always had some problems with the cooling system in my r33 GTS-T, even before i reinstalled the turbo, but now that i have it seems the the condition has become much more frequent (note i have a massive, not my choice, front mount on the car and can only assume that it must be helping the problem, when the car overheated when N/A the front mount was still installed). the latest time has got me thinking about replacing the radiator completely so the engine has more room for error, i cannot find leaks anywhere and i have seen the water boil past the cap valve so i assume this means that the system is capable of holding atleast a little pressure (i have replaced the cap incase that was the reason aswell).
So my main question is there a decent-ish aftermarket upgrade for around $300, i have seen people rave about koyos but they all seem to be out of my price range, so far i have found
http://justjap.com/cooling-pro-alloy-radiator-nissan-skyline-r33-r34-stagea-rb25-rb26.html which is around $250 shipped
or
http://worleyautoparts.com.au/product/alloy-radiator-for-nissan-pintara-skyline-r33-r34-auto-manual-1993-2003-atmt/ for $150
basically i would just like to know your opinions on what the problem could be and/or any preferences on the brand of radiator for relatively cheap.
Cheers
https://www.sau.com.au/forums/topic/469834-radiator-upgrade/
the water pump seems to be fine, the water definitely circulates through the system.
the radiator has no massive dents in the fins but the coolant has become murky rather quickly after the last flush, not sure where that is coming from though.
and i currently has the stock clutch fan and shroud with what i assume is a stock thermo fan (not too sure on that it might actually be on the ac but i've never seen it kick in before it actually starts to overheat) which now that i type this seems a little strange, the a/c getting warm is the first sign in the car that it is starting to overheat which might be the thermo kicking in.... i have no idea now.
Edited by joseph0205
Get the Worley one if you're not making massive power. I used to track my car with that and was decent, until I starting making modest power.
Just file down the thermoswitch port down flat, they are always jagged and don't seal too well out of the 3 I've seen and installed.
5 hours ago, niZmO_Man said:
Reverse flush your radiator and flush your block and heater cores.
I recently flushed the whole system and it worked fine for about 3 months. i drove 8hrs straight one day about a month after and the temps were fine but i barely made it .5hrs 3 days ago without over heating on a rainy day. Could this just be really settled gunk somewhere in the engine?
And anyone else have opinions on Worleys?
I have also found a moshimoto for ~$460 shipped http://www.prospeedracing.com.au/products/mishimoto-nissan-skyline-r33-performance-aluminum-radiator.html
Or a fenix for $360
http://www.sprparts.co.nz/fenix-race-alloy-radiator-nissan-r33-r34-c34-c35.html
Not saying its the solution just yet but should i just go the cheap $150 worley (the car probably makes just barely over stock power, but i have possible plans to try to hit the 300kw marks so not massively stressing the car) or should i bite the bullet and spend the 2-3x more on a decent-ish brand now?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
