R34 Lady in Belgium :D
Hey everyone
I'm Amber, I hail from Brisbane but live in Belgium and I would like to introduce you all to my baby, my R34 GTT "Nozomi".
I found her in 2015 hiding out in someones garage, he had her imported and registered in 2010 - 2011. It was meant to be a 'project' car with his sons but he didn't get much further than reupholstering, getting rid of the limiter and changing the odo over. It has 63000KMs and new coilpacks, got the goodies as well that he already bought but never fitted incl FMIC and HKS hi power exhaust line. The FMIC didn't fit so I sold it and got an autobahn88 one now. The line is so loud and obnoxious even my deaf 92 yr old neighbor hears me leave in the morning. Also changed the filter over to Blitz advantage but for the time being, engine is stock.
Last time I took her into the garage, my expert told me that she was Nismo down to the suspension! And rear-right is busted so fantastic! Plans for the year is a new ECU + map, new injectors, pump etc. See how she goes from there. And also paint the covers and maybe chroming the intake.
Cheers guys!
  • Like 6
https://www.sau.com.au/forums/topic/470215-r34-lady-in-belgium-d/
Thanks guys! ^-^
The R33 and 34's arent a very common sight, R32's are very popular because they can be registered as "old timers" and pay a whopping 35 euro per year in rego. Insurance is miniscule as well and the engine can be modified to your hearts content.
welcome to the forums!
It certainly appears your car has the "nismo" bodykit similar to the altia kit but with a different rear bumper. My old R34 had the exact same bodykit.
My car also came with Bilstein suspension from factory, if yours is the same maybe this was a package offered from the dealerships in japan?
Belgium is RHD right? Is it much hassle driving a LHD car over there?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
