Using aux input for obd2 diagnostic
Hi guys, I have been researching on this site, and have gotten a few plans, but I'm just not sure if it will work.
Will it be possible to connect an obd2 link (thinking HKS OB-LINK) with an android device, and use Torque app to display the information?
Then run that through the aux input of the navigation system to come through the popup screen, as I would rather use it for diagnostics then something as basic as fuel economy.
I am looking for an end result like the picture attached (from an r35)
Thanks
Lachlan
Edited by Lachlan S
https://www.sau.com.au/forums/topic/470227-using-aux-input-for-obd2-diagnostic/
Sure thing. Get the appropriate cable that will plug into your phone's USB to provide you with the respective composite video output and away you go. It won't look as clean and sharp as the real graphics you get from your system (or an R35) but it'll be functional. The trick will be to ensure that the phone itself will mirror the screen via the cable and not only work when you're playing videos, for example. I doubt that will be the case but it's still something you'll need to test. I know my Samsung Note4 works fine in this manner, using an MHL cable which has the USB connector for charging as well as the RCA outputs (eBay job).
Edited by The Max
Your big problem is that almost nothing will talk to the ODBII in our V35s. I am not sure anyone ever has gotten any meaningful data out of our hybrid Canbus/OBDII setup. Happy to be proven wrong though.
Getting the data/display into the factory screen is easy - the amp in the boot has an aux in (that I currently use for DTV).
Ahh thanks, i think ill grab a cheap android (all i need it to do is receive info and display the torque app), and use the composite video. Is there any examples of people doing this before?
Ah really? Damn, I think I heard of some and the OB-LINK 2 says its compatible but I'm honestly not too sure.
How does your DTV input work?
Yeah they all say they are compatible with G35s, but their wiring setup is somewhat different to our Jp V35s.
The DTV is just plugged into the AV in for the screen/amp setup in the boot.
On their website it said nissan v35 with the coupe chassis code. Some people on this website said they had it one theirs, shouldn't it be the same for all jap v35s?
Try and find proof of someone using one and getting all the OBD data to work with Torque.
Hundreds of people have tried hundreds of OBD devices (I tried a couple of different ones many years ago - none worked). If it were as easy as you say, EVERYONE would have one in their V35s.
That said, these HKS units do look good and are fairly recent maybe they will work?
But go ahead - buy all the bits, and if you can get it all to work I will applaud you and follow the exact same route :) Let us know how you go!
Thank you, ill keep digging and let you know how i go.
The only compatibility issue will be with the connector. Essentially, there are two global standards for OBD-II connectivity, though those standards aren't absolute for all and some manufacturer discretion is allowed beyond the basics.
However, it surprises me to hear that a manufacturer would alter their OBD-II connectivity between a USDM and JDM variant of their vehicles. It makes no sense, as that would suggest that my Consult III+ scan tool is made for a specific region, which they're not.
Grow some nuts, take a gamble and test the theory. Someone always has to be the guinea pig, no matter how well researched they are to minimise the loss! ;)
But go ahead - buy all the bits, and if you can get it all to work I will applaud you and follow the exact same route Let us know how you go!
Torque may not work. I have hobdrive working in my M35 stagea. I just checked in the pre defined vehicle settings and it lists 2001 v35 skyline. You can download the demo version for free to check if it works. May or may not. I use a vlink elm adaptor thing plugged into the obd port and connect to it via wifi.
Which vlink adaptor do you use? Do you have a link to it?
also, do you have pics of your setup?
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
