Cam dial in
Hey all, bit of  a brains trust question here. I have kelford cams that I have dialled in exactly to the specs I'm given, and my cold compression test is 170 psi. Was 145 with poncams. This extra pressure makes it impossible to tune. I have dialled them in to within 0.02mm of correct lift at 1mm degree point. At a loss as to why pressure is so crazy high. I'm thinking too much intake advance but it's perfect. Brainstorm please
https://www.sau.com.au/forums/topic/470279-cam-dial-in/
You have another problem somewhere.  170 is a good number. Tuner having a brain meltdown and missing something simple thats looking him in the face?
Are the cam gears vernier type or fixed? Need to know more aboutthe setup that was pre existing and whats there now.
https://www.sau.com.au/forums/topic/470279-cam-dial-in/#findComment-7827209
Hey guys thanks for the replies.
Basically I had specs for the wrong inlet cam. mine was custom made. So I dialled it in perfect (<0.02mm) and comp test was about 160 psi. Once I retarded my inlet 15 degrees and it was correct haha. Worked well. 600nm to redline and 400kw. It was never going to work with the old specs.
https://www.sau.com.au/forums/topic/470279-cam-dial-in/#findComment-7828439
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
