Which AP Racing rotor is the D2/Attkd/G4 356mm rotor a copy of?
As above
http://justjap.com/attkd-front-replacement-brake-rotor-set-356mm-6mm-hole.html
It actually has 8mm holes, supposedly this is the same as the D2/KSport/G4 style brake rotor.
Does anyone know what this is in AP land? Trying to cross/shop/compare brands/see what is out there for a replacement but the AP site has a lot of information which doesn't match.
Figured someone may know when it came time to replace a D2/Ksport rotor, or did everyone buy them from D2/Ksport/JJ Directly?
I did look into the AP rotors for my 330mm ones but the inside bolt pattern was different. However the stock rotors were actually still OK after 3 sets of pads.
AFAIK neither the rotors nor the calipers are a "copy" of the AP racing caliper, it's just that the pads are the same shape and thickness as the AP racing 6 spot caliper.
I've replaced the rings on the stagea after about bllion klm and at least 5 years, I just got new ones from just jap.
  • Like 1
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
