Anyway of comparing torque figures from 2 different dynos?
See attached images. Old graph (Dyno Dynamics), with higher power and lower torque was done 3-4yrs ago using SAFC and SITC.
The only change, new graph on Mainlne, was a Nistune, so I could have some proper off boost/part throttle behaviour and smooth out that torque dip (through controlling the inlet butterflies properly).
Is there any way to compare the very different torque readings wit the info at hand?
Just back calculate a torque number from the power using the normal formula.  It won't be numerically correct, but because it comes from the only thing that actually matters (power at the roller) at least you're starting from the same basis* and can draw graphs to compare.
*of course, excepting the different dynos, operators, tyres, years in between, etc etc etc.
I have torque numbers from both dynos. They are very different (360Nm vs 550 or so).
I know power is just a function of torque vs revs, but given these dynos do various corrections to get their numbers, I have no idea how to apply anything to either number to find something meaningful between them.
It's because the operator on the Mainline didn't use an inductive pickup OR setup the derived RPM via syncing RPM.
Once that is enabled you can select show 'Derived Torque'
/Thread
Even when plugging figures into calculators with known RPM, the output is not like either graph.
All smoke and mirrors.
Oh well, see how it goes Sunday and will just hope that a smoother graph means a better car to drive (yes i know graphs can be smoothed also).
Also the power diffence is sfa when considering its 2 differnt dynos on 2 different days, I'd love to see the boost plot from the dd run as a tiny overboost would explain the hump around 4g on the dd graph
Also the 550nm mainline number in this case would definitely be the bs number as with out a rpm trace there's no way it can give torque reading with reference to the engine
  • Like 1
If you are not measuring the same car on the same dyno on the same day a good way of telling the improvement is to compare say 80 to 120 km/hr times - too late for you now of course. Does the car feel better to drive now?
Boom! Someone that knows :)
Quick report from track day.
Car felt gutless, no surge of torque when it comes on boost. Also a little bit pinging somewhere up in 3rd, was not logging so cannot tell. Had a few misses/hesitation when cornering (car has surge tank setup) though tuner did note fuel pressure was fluctuating quite a bit with temperature.
Despite the car feeling gutless and less powerful than I remember it (a few years ago) the max top speed down the straight was identical and the lap time was within 1 tenth of the previous PB 0_0
Given the max top speed was the same, I'd say so.
Though I need my old phone to look at the Race Chrono data and see if the corner exit speed onto the straight is the same to be sure.
Not after seeing GT-Rs "economy" on e85 and the fact I can't get it here. Annoying enough bringing back 80L at ta time for the GTR (which ate 140L at winton...)
Silvia wouldn't be as bad, but still. That means injectors and a full retune on e85, or additional e-flex sensor then really should go to proper boost control etc etc.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
