Did anyone get footage of the cars on the heritage display drive? Our in car footage was pretty terrible. I'd appreciate it if someone could share their video of the drive with me? (Hoping someone was in the stands).
  • Like 2
@DJBarnstar, hats off to you mate, you were ripping it up all day.
I watched a bunch of your motorkhana runs... i'd say committed about sums them up. You were damn quick.
  • Like 1
31 minutes ago, PranK said:
There must be more pics?
Full dump coming through. It looks as though i spent too much time talking, not enough time taking photos...
Edit: mine are in chronological order (because lazy).
Edited by Steve85
4 minutes ago, PranK said:
Did you trailer from Melbourne? That's commitment!! Well done!
Sure did... I'm not sure I would do it again. It wasn't the easiest thing to do. But it was certainly worth doing once. I met heaps of super friendly people and a lot of people knew that my car was an LM Limited, which was a pleasant surprise.
I had an awesome time, and wish I had done a couple of passes on the drags or gone in the motorkhana. Next time, hopefully someone else brings some cars up and I can share shipping with them and just fly up.
Also got to chat in person with Josh and Chris from Galvsport. These were the guys who built my car and who got it ready for shipping. Until Saturday I hadn't met them at all. Top guys and really friendly. Worth the trip just to meet them.
  • Like 2
Thanks Steve,
Shame we didn't get to chat!
I must say that was all Daisy had. I've never tried a Motorkhana with street tyres before and in many ways was a lot more fun than with Semi's!! Loose as!
Pretty meh with the times on the drag strip though. Obviously not making the power that the dyno graph would indicate.
Best car meet I have ever been to. Ended up getting 7 Moto runs and 7 drag runs and was still able to drive back to Canberra that night with no breakages! Winning!
  • Like 1
Here you go :)
  • Like 2
On 6/3/2017 at 6:23 PM, PranK said:
I think my first post is confusing.
Upload as many as you want into this thread. Then we do the competition later with an image you pick.
I want to see what I missed out on!
SAU.NSW Section.
"...what you missed out on!" ;)
This ain't my pic, so it's not in the comp.
  • Like 4
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
