Rb25 det running poorly - coil related?
not sure if related to the coil or dirty plugs but my rb25 seems to run with a struggle in low rev range. The rev range is not smooth and feels like its spitting.
It has 5 red jacket coils and 1 standard coil which the previous owner diagnosed as the cause of the issue.
Im in the process of removing plugs and just needed a confirm from others who have had this issue resolved.
is it the odd coil, dirty plugs, or both?
Thanks
Edited by AARR34
Could be anything but borrow a known good set of coils to confirm. I would only use genuine OEM coils or Splifires. Pull the plugs while the coils are out and if they are not in good cond get a new set gapped to 0.8mm
  • Like 1
Is the problem noticeable at idle?
If so, pull coilpack plugs one at a time while idling. Listen for a note change as you pull the plug. If there is no note change or a less pronounced note change one one, then chances are that is your dud coil (if that is indeed the problem)
  • Like 1
yeah it happens in idle and gets less noticeable as the revs climb.
I just hope its nothing major to do with the motor. I'm getting new plugs to go in with the coils. The owner had mixed plugs and 3 of them require a larger socket to take out.
I don't get why people do that
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
