Wrecking Skyline R33 GTS-T Turbo Manual. Whole car available for $8000 without the wheels pictured. can be registered, clean title and clean body, no repairs before. Put a carpet in and engineer the roll cage and it can be registered.
RB25DET Engine - $2200 as it is, negotiable by removing certain items.
- ARP Head Studs (no more than 50kms old)
- Head full reconditioned with valve seals replaced
- Permaseal Multi layer steel head gasket (no more than 50kms old)
- Rocker cover gaskets replaced not long ago (no more than 50kms old)
- Gates Racing Timing Kit with water pump (no more than 50kms)
- Kinugawa Turbo, GT3076 equivalent
- Iridium Spark Plugs
- Splitfire Coilpacks
RB25DET Turbo Gearbox $1800 - NOT NEGOTIABLE
Manual Conversion Kit - $2200 (available unless gearbox is sold)
- Lightened flywheel (no more than 50kms old)
- Exedy Heavy duty button clutch (no more than 50kms)
- Master & Slave Cylinders
- Clutch Lines
- Pedals
Complete Full adjustable suspension arms set - $600
- Adjustable Upper Control/Camber arms front pair
- Adjustable Upper Control/Camber arms rear pair
- Adjustable Lower control arms, front pair
- Adjustable Lower control arms, rear pair
- Adjsutable Front Castor Arms
- Adjustable Rear Toe Arms
- HICAS Lock Bar
- Greddy Boost Controller - $300
- DBA T3 front & T2 rear brake Discs - $250
- Front mount intercooler kit - $250
- Alloy Radiator - $150
- GT-R  carbon fibre Bee-R style wing extension ONLY - $450 (does not include the GTR spoiler body/base)
- Genuine R33 GT-R 400R (aluminium twin blade spoiler) - $1200
- AGI Bolt in half cage - $600
- Genuine Sabelt 4 point harness, driver and passenger - $200
- Whiteline Sway Bars, Front and rear - $300 (cosmetically worn but still works fine)
- Ohlins Adjustable Coilover Suspension - $2000
- R34 HKS Full Turbo back exhaust - $350
- Greddy Catch Can - $50
- Greddy Strut Brace - $200
- B-Pillar Floor Brace/Monke Bar - $200
- Headlights Pair - $600
- Front Bar with Fog lights - $450
- Grille - $150
- Bonnet - $250
- Driver Door complete - $200
- Wheels with good tyres - $1000 (not negotiable, I'd like to keep them but would let them go for the right price)
- Reo bar - $150
- Side Skirts - $150 pair
- Rear pods (in gun metal grey) - $100
On 02/07/2017 at 2:27 AM, MagicPants said:
Seat for sale ?
sorry for the late reply, yes they are for sale, have the pair for $400
  • 4 weeks later...
  • 3 weeks later...
On 8/22/2017 at 5:44 PM, MagicalZorse01 said:
Interested in the drivers door, is it fully complete? And also would it all work on a series 1?
The door is mostly complete, window and regulator is there and working. only door trim is missing. Will work on series 1, PM me.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
