Dual Tial wastegates and spring choice with MAC
Hey guys,
So I recently switched to a 6 boost high mount running dual tial MVS 38mm wastegates. This will be my first time running this type of setup, target boost pressure will be 30, but possibly 35 psi. Both will be controlled by a MAC valve going back to a Wolf v550. Engine is a built 26/30 with borg warner 9180 turbo.
I have setup the springs in both gates for 23psi, with the idea that the mac valve can do the rest to 30. Can someone tell me if that's going to be OK?
Some people have told me that running 23 might be an issue when time to tune, is this correct?
Cheers.
You are assuming that your set-up will run OK at 23 psi. If you are confident about that - no problem - but if there is any doubt you should have a set of lower springs to hand so that you don't have to return to the tuner for another session. Also if you find that you will be regularly running 35 psi you may want springs for 28 or so psi.
  • 3 months later...
As mentioned above, double check how many port MAC valve you have and if it's not a 4 port, buy one. MUCH better control and you can run softer springs with a much larger range.
FWIW, I'm running 0.9 bar springs and have no issue at 26 psi (bringing it back to 23 up top on purpose) using 4 port valves.
also I'd recommend finding a 12 watt solenoid version of the 4 port mac valve (made by circuit seven on ebay). they control duty cycle range is much greater (40% greater effective duty range) giving you better control resolution as the 4 ports are sensitive.
also a lighter spring in the gate will allow the valve to respond faster. as long as your diaphram to valve area is decent (>1.5), a 4 port will hold it closed with a very light spring.
effective duty @ 30hz for the 4 ports:
5.4watt is 22-62%
12watt  is 14-70%
alve
freq
approx Duty range %
3port MAC-5.4 watt
10
7-90
15
10-89
20
15-86
25
17-80
31
20-80
40
26-68
3 port MAC-C7-HI-FREQ
31
15-85
40
17-82
4 port 5.4 watt
10
9-87
20
16-70
30
22-62
40
25-40
4 port C7-HI-FREQ
10
6-90
20
10-80
30
14-70
Edited by burn4005
  • 3 months later...
i have the same setup
i followed tial’s spring chart for 23psi
for some reason we had boost reach 37 psi
i used two springs not the recommended 3 springs and boost stayed around 20psi
i would start with two and a 4 port mac valve that way you can go 20-40psi
my mistake
i’ve plumbed it wrong
follow Tials instructions PROPERLY and they’ll work fine
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
