  On 01/09/2017 at 11:45 AM, fatz said:
Over the period of 10 years I have got about 20 slabs and had my trailer rebuilt 3 times by people borrowing it
dont lend trailers
Expand
This!
Since buying a new trailer I've never loaned it out and have no intention to. Previous trailer was damaged each time someone borrowed it. People have no respect for others' property.
I hear this alot. I guess it depends who you lend it to.
A mate bought himself a newish trailer recently and is very selective about who uses it.
If he doesn't like their style he just says no, simple as that.
  • 2 months later...
A decent tilt trailer is 3-5k.
Borrowing the neighbors costs me $40-50. At the local track here's a spot to get it on and off without the extra ramps.
Reckon I can hold out a bit longer while I'm still able bodied lol
That trailer looks like it weighs a ton but of course it depends on the distances you tow and the load as to how relevant weight is. My 500kg Tilta Trailer is brilliant, solar panel keeps the battery charged, from Qld it's been to PI and Bathurst twice, slight buckle in one alloy wheel after hitting a monster pot hole at speed.
Probably not light, but I've never needed to go more than an hour down the road with it and the Silvia isn't too heavy.
I will say, I had to limit my speed to 100 when I towed the GT-R as it got a little wiggle on above that regardless of where I put it.
Yeh my Cherokee is rock solid towing at any speed including braking down hill, the PB Challenger diesel was a POS compared.  The C's long wheelbase with the rear wheels close to the towing point and generally good dynamics helps a lot.Engine just needs a chip.
Is it the latest one that has all the electrical issues?
For the price difference, gotta say I'm making do just fine with the Terri (free work car).
Though I was thinking about adding a trans cooler when I fit the brake controller for a pending camper purchase.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
