R33 gtst missfiring problem?
Hi everyone,
This is my first post and I'm after some help. After reading many threads about people's misfires in their r33 s1 gtst I can't come to a resolution of my problem.
I have a fmic, full exhaust, 10psi.
Under full throttle any gear it makes a mini gun rapid fire out the exhaust with no power. Does not happen when gradually accelerating. I have replaced since it first started; fuel pump, fuel filter, spark plugs gapped to 0.9 (previous plugs were 0.8 and same issue), tried original and super spark coil pack both second hand. Still am having problems
Could it be my igniter? The problem was not there before I installed fmic and bumped up boost. I haven't yet tried sealing my coilpacks with high temp sealant.
I have my car booked in for highflow and tune monday so would like to get it fixed before then
Any advice would be awesome
Cheers Mitch
https://www.sau.com.au/forums/topic/471732-r33-gtst-missfiring-problem/
Sound's like R&R (rich and retard).
The stock ecu is seeing more air than it's used to so it tries to protect the engine by adding more fuel and retarding the timing. This would make sense since the problem started after you installed the fmic and raised the boost which would result in increased airflow.
This causes a loss of power and the misfiring feeling. You could try clean your AFM with some MAF cleaner and dropping the boost 1 or 2 psi, the problem should go away then.
Are you sure you are running only 10psi and not higher?
Hey,
thanks for your reply. I've got a 32ecu z32afm and a highflow + tune going in Monday. But I just want to make sure everything is working before I give it to mechanic and get charged an extra $100 an hour to repair my coilpack etc.. I'm positive only 10psi boost. I'll try cleaning my afm and I'll drop the boost back to 7 and see how that works
Problem(s) could be from either the Superspark coils (which are rubbish, sorry to be blunt) or faulty OEM ones.
Best to get Splitfire ones or go Yaris conversion or LS conversion coils.
Don't really want to spend $500 if I don't have too. Might try afm cleaner and see what tuner does. Do you recommend using that silicon or electrical tape around coils as a resolution?
Sure, none of us want to spend extra money but if your coil packs are buggered or you spent $400 when you should have spent $600 then the only way out is to spend $600.  Not $500 or $400.
Always buy Splitfires at minimum.  Do not try and go cheaper.  You will only end up opening your wallet again to buy what you should have bought the first time.
Doubt it's coilpacks as it wasnt like it before I bumped up boost, installed fmic and full exhaust
I wouldn't not doubt the coilpacks in that assumption. I'm not saying that it is your coils either but if they're weak it shows up when boost and power increases.
As above, if buying new coils stay away from the bright coloured ones unless they're the bluey purple ones, otherwise OEM or conversion.
I'm going to entertain the R and R theory.
Tried both coilpacks, and screwing boost tee fully which isn't making boost any lower then 9. Unsure why. Might have to plumb it back through my apexi boost controller which used to run stock boost 5-7psi. Will give that a shot tomorrow, if no luck, will try and tape coilpacks or look for cracks in OEM ones. Will R&R still occur when I lower the boost? I know it's running rich because I get 200-250km  tank and that's not even thrashing it
Just now, vxsr33 said:
So did you test drive it at 9psi and it's still cutting out?
Just take off the boost T and use a straight through connector if you have one. R&R shouldn't occur once the boost is lowered.
Yeah I'm going to put it through my apexi boost controller tomorrow arvo, which is turned off so it runs stock boost which it used to. This will tell me if r&r or coilpack
That should give you approx 5 psi (assuming you have stock turbo with stock actuator and the stock boost solenoid is eliminated) which will certainly eliminate any over boosting and R&R.
R33 stock ecu is notorious for freaking out around the 10 psi mark, sometimes you're lucky, sometimes not.
Definitely clean your AFM / MAF with the proper MAF Cleaner like CRC as even the slightest bit of crud can cause it to read incorrectly.
  • Like 1
Okay cheers man, I'll grab some CRC MAF cleaner tomorrow.
It's a little exxy but great stuff, I've used it on every car I've owned running a MAF and it has improved idle smoothness and fuel economy on all of them.
Should be part of your general servicing and maintenance routine but is often forgotten.
My R33 (running 10psi) did what yours is doing once but the MAF cleaner fixed it. :thumbsup:
Should be part of your servicing and maintenance routine but is often forgotten. :)
Okay thanks for that, if it nots the AFM or the fact it's running higher boost with a fmic, would you definitely say it's coilpacks? Since I've replaced pump and fuel filter already. Would you wrap coilpacks in electrical tape? And if so what part do you wrap? If your not sure all good man
No I would not as there's still too many variables. Start with the easy and cheap fixes and eliminate them first.
What pump did you put in? Did you feed it a new 12 Volt line via a relay or just use existing wiring?
Some after market pumps don't like old stock wiring.
Check the coils for cracking and wrap the whole long bit to eliminate any arcing if need be.
Existing wiring , walbro 255
Might be ok, but try the other things first (CRC and coil wrapping) and go from there.
Heaps of info in this site about all these things as they have all been covered many many times over, so have a mad search, read up on R&R, misfires, Fuel pump installs etc etc.
and go nuts!
I know I sure did. :yes:
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
