Need help losing oil but no oil leak?
Hey guys!
So ive got a r33 gtst.
Its got 180kms and im losing oil like crazy when i hit boost. Its stock besides fmic, exhuast and oil cooler. I noticed about a week ago my oil pressure has dropped but have done a major service 3 weeks a go. So i check the oil level and it was near empty.... looked around and couldnt find any oil droplets and/or puddles. Ive checked everywhere i park my car and no oil on the ground any where. But i did notice that the rear of my car get small oil marks (cars not running rich) . So i believe i have oil coming from the exhaust but dont know why. Please o wise ones share your knowledge with me! This is my dream car and i have owned it for 2months now and praying i did not buy a lemon :(
Did you do the service yourself? Fill the oil exactly to the mark on the dipstick?
Fill it again today and monitor the level for a week or two. If it has burned off a couple of litres do a compression test and then repeat it with a shot of oil in each cylinder to  see if its the rings.
Nah didnt do it myself had my mechanic do it.
Yeah ill get a compression test tomorrow or wednesday and post results
Few questions that might get you some better answers....
1-  any smoke at all under boost? Or any smoke under any driving conditions?
2- how much oil is your engine using?
For example if you dropped the oil now and put 5 litres in.  How much oil would you have left if you dropped it after say 500km of driving.
3-   what oil are you using now?
4- any leaks around your sump area or underneath engine that you can see? Wet looking spots....
5- i like cats, would this shirt make me look gay at powercruise.
  • Like 2
Can you give me an answer for both if i said yes and no? Because i havent seen any smoke but then again never had someone stand behind my car and tell me.
So 3-4weeks is almost empty.
10w 40. My dad told me to get maybe thicker oil cause the cars done 180kms but not sure?
Doubt it because only park in the same 3 spots everyday and no drops or anything on the floor.
f**kkk no! Get me one! f**k dat gucci shit get me one of those and ill wouldnt give two f**ks about mi car :P
3-4 weeks of driving and its chewed through 3-4 litres of oil doesnt sound good.
Im not a mechanic, im not going to tell you whats wrong. Maybe someone on here will steer you in the right direction. My amateur mechanic guess is oil is going past your rings and being burned up.
Or you have a serious leak that you really havent found. Do you park on grass? Or where there are rocks? So you wouldnt really see a oil spill. Just saying,  might be something very easy to fix or something expensive.
Edited by Cyko34
So have you topped up the oil or are driving around not knowing how much oil is in the sump?  If not buy some oil and drop 2L in, dip it , and then add 250ml at a time so you know how much you are under the full mark. It sounds as though you have limited mechanical knowledge and are using a workshop for everything which is sensible but in order to save money and learn to have confidence in your car it is good to start doing the basics (oil change, plugs etc) yourself.
2 hours ago, MrR33SKI said:
Dam im hoping its just the turbo?
But how much would i be looking at for piston rings?
$200
The bottom end build to install them though...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
