48 minutes ago, Piggaz said:
Thank you!  Many curves there to give me good data points!  Except the curves in kw show kph at the bottom instead of rpm, and I'm incapable of converting that even assuming it's pulled on 4th gear.  :7_sweat_smile:
Edited by TXSquirrel
Not completely related but I don't want to start a new post...
How much power or psi can RB26 factory head gasket typically handle?  I am trying to determine how far I should push my current setup...
Ahh I see, so the limit is the head bolts and not the gasket.
My -9s are maxing out at 17.5 psi, more than that it's getting knocks because air is too hot.  So if the 28 years old head bolts can take 350kw, I will invest in a good intercooler and see if I can push to 20 psi.
24 minutes ago, Piggaz said:
That doesn't sound right.
time to look at your tune
That is fresh off the dyno, and the knock happens at the top of 1st and 2nd gear.  Still has plenty of injector to go, and we fill tank with fresh petrol just to be sure, still knocking.  Plugs are iridium heat range 7 gap to 0.036" / 0.9mm.  We could get 415whp / 310kw consistently with no knock at all at 17.5 psi, but not more.  I would guess room temperature was about 85F / 30C, so whatever that gets turned into with fans blowing.  Both coolant and oil temp was around 190F / 88C.  Conclusion is charged air getting too hot with factory intercooler.
I think that's pretty good power at 17.5 psi, but kind of wish it could go to 20 psi.  Curve is identical to factory setup until 4000 rpm, so that tells me nothing major has gone wrong.  What's -9s optimum range anyways...?
I'm thinking Plazmaman, but I'm not sure if that's too big for -9s at 76mm thick.  Greddy's is 70mm thick and HPI is 72mm.
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
