1 hour ago, ActionDan said:
How much did sponsorship save you do you think?
Maybe a 1000 or so for this event the main sponsor is a multi event thing that will be continual for the rest of the year.
  • Like 1
Amazing, dunno how TF you pulled that off but well done.
2 hours ago, PranK said:
Do you need some? That would be awesome!
I've still got a few from members pack. Will get them on, get picks and post/tag on instagram.
Known the business owners for a long time, spend a bit with them over the years and send lots of people their way. I was amazed by the support I've gotten considering everything that's been happening.
For those that do the instagram thing can follow stuff over the weekend at robert_ponystumble
  • Like 2
You're famous, spotted your car in the last sprint on Foxtel. Had a bit of a moment while your car was on screen. Commentators even requested a replay of it. Other than that little boo boo, car looked like it was going and handling great?
  • Like 1
The foxtel coverage was great, did a slowmo yesterday that was cool. Yep overcooked it over taking a slow car and got on the power but had more grip than I thought.
Weekend wrap........
That was EPIC
Started off Saturday just working up to a comfortable pace and ended up with a 1:31.4.  Lost a bit of brake pedal feel by the end of the 3rd session. Did a bolt check, bleed brakes and scuffed the brake pads at the end of the day. Todays first session car felt good and brakes were so much better did another 1:31.4 but car was breaking down under so pulled the spark plugs, gapped a new set down to. 6mm and drained the rad overflow back into the radiator. Was pretty confident as hadn't pushed hard yet. 5th and last session I knew I had a fair bit left in it so went hard and got a 1:28.936 which left me 2nd outright behind Paul Morris in the CAMARO. Car pulled like a freight train on the straights and brakes were really good.
Car is in one piece but I think may have finally hurt the motor, blowing a bit of smoke and losing oil pressure. Learnt heaps and had so much fun. Will look at the car after Targa Great Barrier Reef next weekend.
A few pics of the weekend
  • Like 5
29 minutes ago, Dose Pipe Sutututu said:
Nice work! 2nd outright is amazing!
Jumped the gun on that, turns out it's 4th ? 2 race drivers and a 500kw R32 gtr got me.
Brakes worked really well. One of the commodore Ute's exploded a set of ebc yellows.
  • Like 2
That's still very impressive! Great work also glad the Elig Pads are performing well! They do get s bit squealy when warm but it's that or non working EBC like brake pads lol
  • Like 1
You'll probably be getting a few more enquiries about brake pads soon.... People were shocked I only had r33 calipers with good pads and fluid so many people didn't even think about getting at least good fluid before the event ?
  • Like 1
6 hours ago, ActionDan said:
Nice!
Yeah, it's a different level of car than what I'm used to.
4 hours ago, Dose Pipe Sutututu said:
Great you're enjoying your car, you've raced it more times this year than I have in a space of 5 years LOL
Pretty lucky my lifestyle let's me, when is the next time you heading out to the track?
Heading out again 14th September, see how I go with new alignment, refreshed 2-way and more balls lol
  • Like 2
Was having an epic weekend 5th outright and 1st in class and ended up with a hole in the block after the last stage transiting Saturday afternoon. Beat the r35 on one stage.
The old vh is a weapon and getting a few upgrades.
Going to have a bit of time away from cars...................................
For like a week
A few pics, there's heaps on the cars facenovel car689 and momentgram ttcar689
I got this pic while waiting for the tow truck
  • Like 1
Haven't checked the logs yet and engine builder will get it and diagnose. But it had seen limiter a bit through the stages and had a fuel problem earlier in the afternoon.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
