Hey guys, I know this is an AUS forum however I'm not having any luck with support in the US for the Skyline, in fact the Nismo guys are less than helpful and rude to boot.
Purchased a 1990 Skyline GXi chassis (FR serial number) with an RB20DET swapped into it. It was a real mess wiring wise. I'm still trying undo the damage done. The car is an A/T which is good for me since I'm a cripple. I won't lie, I'd love a 5 speed, but it's hard to shift with my condition.
Fast forward to a week ago, I took the car off the road, took the entire interior out (carpet included) and I started figuring out where to begin. I yanked out the entire chassis harness and TCM, it was a nightmare and when I download the pics from my phone I'll share the build. It wasn't pretty. It was rat's nest of wires under the engine fuse box and even bigger mess near the ECU. Somehow an R31 ECU was hard wired into the harness to work.
I found a new chassis harness off of a GTS-T which was A/T and came with a new TCM for $200. Sweet deal and when I got it, it was unmolested! How rare is that? I ran the fuse box, I ran the entire chassis harness from the dash back to the tail lamps. Everything looks good. Even came with the Clarion amp and wiring (it'll be removed). Even had the EGT probe for under the passenger side seat, again, something mine didn't have.
It took me a 2 days to realize that the engine harness was a separate assembly and I needed to buy that in addition to. So I ordered it and it's on its way now from Japan, $300 later. So now I'm $500 in on wiring but it'll eliminate a lot of issues. I'm assuming the engine harness has the wiring for the alternator and starter unless that's somehow a separate unit? Shouldn't be (hopefully)
Halfway into my dimwitted effort to replace the harnesses I decided "Hey let's order an RB25DET NEO with A/T trans." Found one from a reputable source in Canada for $1,700 shipped.
So now my big question is what is it going to take to get the 25 motor to work with the 20 harness. I've spent about a week searching and found the general details like swapping two injector wires on the RB20 ECU and RB20 harness when installing the 25 motor. Though the transmission is what eludes me.
I haven't found any posts, threads, information pertaining to running an RB25 auto trans on a RB20 harness. From my understanding the RB25 ECU controls both transmission and engine. If that's the case then what's my next step to make it work? Should I just try to find an RB25 auto chassis and engine harness and scrap everything?
https://www.sau.com.au/forums/topic/472367-new-r32-owner-in-usa/
32gxi, thats rare.
getting the 25 while everything was out is the best thing you could have done.
we have allot of yanks on here so your in good company,
also welcome and build thread or ban :)
Thanks mate, unfortunately there's no yanks here so I'd be relying on someone over in AUS to yank the Rb25 chassis, engine and trans harnesses.
Since that's not a feasible option, any possibility of wiring in the trans to the 20 harness?
The RB20DET ECU should be able to run the RB25DET engine. However if the RB25 has VCT then you will need a separate switching system for that.
But if the RB25 auto ecu is in the engine ecu then your RB20ECU may not do the job. You will need to google for some wiring diagrams to see if the RB20ECU has the auto ecu built in. Sorry don't have time at the minute to research it myself but would be a good idea for you to sort this before you spend ny more money (hopefully someone will pop up who knows the answer).
In the meantime how about a couple of pics of your car?!
Thanks @KiwiRS4T we figured out that the RB20 ECU can and will run the RB25 motor, however it won't run the RB25 transmission which is where my headache is.
I've been scouring the internet for a while before pulling the trigger on this build. Ideally identifying and sorting out the wiring issues first and moving to mechanical second.
There's some pictures of the Skyline. The badge on the back says GTR (previous owner) and the badges on the side say GT lol. So there's no consistency whatsoever, though I'd like to make this car my unicorn and do the unthinkable by dropping the RB25DET motor and trans into the R32 chassis and unleashing a monster onto the world.
  • Like 1
GT badges are on all R31's through R34 (i think) as well as S13 through S15 (again, i think) the colours of the GT badge represent whether the car is turbo or not.
Looks nice! I thought US could only import GTR's?
Welcome to the site. We're definitely not Aus only. :)
The badges I have are all discolored actually so there's no telling what it was, I'm assuming red as the car is boosted. Though as you might have seen in my other thread, I plan on doing a neo swap, the challenge is the wiring. I won't go into too many details lol.
Trying to score C34 or R34 GTT chassis harness and cluster so that I can run in the car. Wouldn't be fun otherwise.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
