i have an r33 gtst and just had timing belt and a new exhaust manifold put on cos the old one cracked in half, the mechanic said my lifters are noisy so that must be the wining noise when im driving, anyways i know my oil needs changing so i wana put something thicker in to quiet it down a bit cos its loud at idle, would a 10w40 do it or what would you recommend
https://www.sau.com.au/forums/topic/472436-oil-to-help-quieten-engine/
yeah sorry i didnt explain it all properly, the engine has a loud tick when its idling, very loud and i suspect that the oil is stuffed cos i havnt changed it in years, i just keep topping it up instead so i think that might be contributing to the noisy lifters so i want to get an oil thats maybe a little thicker so it will quiet down lifter noise so that why i was asking if 10w40 is a good idea.
so if anyone has any suggestions on what weight of oil i should go for a car that has 180,000k on the clock and has noisy lifters.
Secondly im not sure if this other noise is from the lifters but it seems that when im driving the car it seems to whine, almost like those kids toy cars that you push a few times to wind them up and them let them go, it gets louder and faster with rpm. I just thought it was cos if the lifters cos the car is going faster so that knocking/tapping noise gets faster and turns into that noise i get, but now im not so sure. I just had the timing belt done by a mechanic and he probably just used a standard one, the noise was happening before the belt change and i could even hear it over the noise of my broken exhaust manifold, more of a winding noise than a whining noise. i will have to check to make sure its not from the alternator and i read that a power steering pump can make a whining noise but i dont know if its the same type of noise im getting.
could i take the power steering belt off and take it for a drive to check if the noise is still there or gone??
anyways guys sorry for the long post, but i really need to go get oil in the morning cos it needs changing bad so does anyone have ideas on what weight to get??
I would use an engine flush then use a 10w-40 oil, i prefer 0w-40Mobil 1 but whatever. Maybe in your case i would do a oil change with some cheaper oil and then repeat flush and oil change after 2000kms to help flush the crap out.
Then id disconnect all auxillary belts for a few brief start ups to help figure out the whining source.  But from my own experience the OEM timing belt does have a slight whine to it, and hopefully you did the water pump and idle/tensioner bearings with the new belt and its all correctly tensioned.
Edited by AngryRB
Any new oil is going to be better than the oil in your motor at the moment. Even a shitty bottle of 10W40 Magnetec will be better.
yes thankyou thats exactly what i done, i used the nulon engine oil flush and ran it for 20mims them dumped the oil and put a new filter on it and put some cheap 10w40 semi synthetic in it cos i will dump it in a week or so and then put another new filter and some good full synthetic in it and then it will be good then.
When i put the oil in and started the car i wasnt too happy cos it was still ticking/hammering pretty loud, i drove my misses into town to work and back and it was still loud, so i decided to go for a better drive and give it a bit of a punch and by the time i got back the noise had gone and sounds luke a brand new bloody car!!
I recommend anyone who has the dredded lifter ticking/hammering to do this, it worked for me and i couldnt be happier and i know the engine is much much happier as well
and i should also mention that when i say i gave it a bit of a punch i dont mean i broke the speed limit or anything, i just more got it from 0 to 110 quickly a few times. i would not recommend speeding especially when your taking the car for a drive cos the lifters are very loud, cos if they are stuffed it could cause a major engine failure i would assume.
Nothing wrong with the cheap semi synth oil, full synthetics advantage is longer change intervals. Oil tech has improved since our cars were new, so there is no penalty in using the cheaper stuff. I'm of the opinion that cheaper oil changed more frequently is an advantage because it removes more sludge from the engine. For turbo engines I change the oil every 6 months or 5 000Km, which ever comes first.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
