Gidday.
As suggested I require some help in working out my comp ration. I have researched the heck out of this subject and have found some really good posts with very VERY detailed information and processes in order to a quote this information. But nothing about how to adjust the ratio. For instance from what I have found the RB25DET S2 Came out with a 9.0:1 Ratio from factory also here are some other specs I have found for a stock RB25DET.
SIZES ARE IN MM AND ALL FACTORY.
BORE SIZE             : 86.0MM
STROKE                 : 71.7MM
DECK HEIGHT      : 188.5MM
HEAD CC              : 66.5MM
COMP HEIGHT   : 31.5MM
So here is my information
RB25DET S2 Block.      Decked 10 thou
Rb25det S2 Head.        Deckedb10 thou
Bores.                            +20 thou
Stroke  (Stock)              71.7mm
I am looking for between  8.5:1 to 8.8 - 9.0:1
I am not as smart as some and cannot seem to figure this calculation method out. The instructions and walk throughs I have seem are really detailed but a little TO detailed to the stage where I am lost and it all starts looking like the matrix wall paper screen saver.
So if someone could help me understand and to figure out what pistons I should her what Head gasket and so I will be forever in your debt.
I had my rb25det with full stock internals up to 444.4 RWHP @ 19.5 @ 19.5PSI Of boost and snapped piston 1-s Ring Landings.
Thank You In Advance.
https://www.sau.com.au/forums/topic/472644-rb25det-comp-ration-help/
On 11/11/2017 at 8:34 PM, KiwiRS4T said:
Stock is fine 9 to 1 is fine ...properly assembled and tuned CR will not be the cause of engine failure.
I am trying to ascertain the compression ration I have now as compared to the stock 9 to 1.
9 to 1 i if everything is factory.
I have a 10 thou decked head
10 though decked block so that would raid my compression to 10 to 1 and over.
But if I use a 1.3mm gasket it will lower my compression.
I am guessing lower then 8.5:1 andbdeffinatlu lower then 9.0:1
If I use a 1mm head gasket it to will lower the comoression ratio but to what I do not know.
My guesses and assumption are basses upong the given information.
Standard is 9.0:1.
Deck head 10thou and block 10thou so if everything else is stock it would mean that my compression height is 20thou or 0.5mm shorter and my piston now comes closer to the valves and the head meaning higher compression.
If I try to compensate for the 20 thou differance and use a 0.5mm or 20 thou head gasket it should in theory bring my compression back to stock (9.0:1) If I use a 1mm or 40 thou head gasket it would mean that my compression height is now lower then 9.0:1 as the pistons are now 20 thou lower at TDC which inturen will lower my comp ratio.
If I use a 1.3mm or 51.118 thou
Meaning my comp height is now 30+ thou taller meaning my comp is now lower.
So
With all this information I still cannot work out my assumed comp ratio.
I'm guessing that with a 1mm (40 thou) MLS Gasket my comp will be lower then 9.0:1
And a 1.3mm (51thou) would make it lower.
But I need to know what it would be lower to.
So if anyone here and I am seriously confident there is.
Has done this
● what type of pistons were used and
● what size head gasket was used. And
● Comp ratio was achieved.
Thank You.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
