I was reading about a guy in the states who did a 'LCI conversion' to his E90 by sticking red tinting on his tail lights. While this is in no means an 'LCI conversion' I thought it looked so much nicer than the clear reverse lights so I bought some pre-cut tint from the states and put it on today. Its not perfect with some tiny air bubbles but I'm hoping that by leaving them in the sun they might go away, I think it looks so much better as the tail lights are, for me, the weakest design link on this car.
  • Like 2
imageproxy.php?img=&key=4b1e78680f916b86
Um but do they glow red when you are going backwards? Would be illegal and confusing.
  • 4 months later...
I just realised how long its been since I updated this.
So, I'll add what I've done since March.
Oh, also, my VVT motor is leaking oil into the spark plug holes #3 & #4. Its not much of a leak but its causing the odd miss which is irritating me. Been quoted $800 but it looks pretty straight forward and might give it a go myself.
Also, during my must-keep-warranty 6 month oil change my intake pipe was noticed to be not entirely attached allowing unmetered air into the engine. This was fixed which made the car a little more responsive.
I changed my angel eye bulbs to LED's. I purposefully didn't get stupidly overpowered ones as I didn't want the angel eyes to be like little suns, I just wanted them whiter than the halogens and slightly more noticable.
Here's drivers side done, but not passenger. Fairly different, passenger doesn't even appear on.
Both done in the daylight.
Here they are at night. Not bright enough to light anything up, which was the desired effect.
I need to get pics of my interior changes...
But, I totally had enough of my seats. They were horribly uncomfortable and like sitting on a bench.
I got some absolutely mint M-Sport seats. They are soft and the leather is gorgeous. Lots of left and right thigh support and an extended thigh base at the front. They also have air-filled bolsters though if you are larger than the average 3 year old you may need to leave them empty as they get seriously tight.
I also picked up a BMW Individual steering wheel! Its so fricken cool though a little banged up. I'm trying to bring it back to its former glory but its already so much nicer to drive with than the bus wheel that was in it before.
One thing I noticed on the car the first time I saw it was the terrible state of the window seal trims. The front windscreen is totally missing and the rear just looked horrible.
Here's how it looked and it was killing me every time I looked at the back of the car.
The other issue was that somebody had glued these pieces on which was a real mess.
Anyway, once they were all off I gave the glass and the car underneath a good clean and then a spray with silicon to assist in getting the new trims on.
End result is so nice. Its one of those changes you make that you keep noticing every time you look at the car. Seriously satisfying, its been eating at me since I bought it.
Some black glue still on the paint to this day, need to hit it with some bug and tar remover.
Passenger side isn't perfect but no amount of manipulation would fix it. I just left it, as its not glued in I might try to fix another time.20180721_150442.jpg
My drivers side tail light has always been cracked. I picked up a replacement and its another satisfying fix. Its so much cleaner than the other side though I'm now considering buying its pair to make both sides nice and clean.
Anybody know how to get this off? Its so irritating and no amount of scrubbing even makes a dent.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
