Not sure if correct place admin please move if needed.
Half way through a RB25DET neo into R32 swap and needing to replace the heater and other hoses.
from what i can gather the RB25DET Neo heater hoses are what i need but please correct me if i am wrong.
apart from OEM what options are out there. i have found Misc eBay ones mainly listing RB26 or R33 25
and JJR do not list a Neo kit.
https://www.sau.com.au/forums/topic/473290-rb25det-neo-heater-hoses/
I don't remember the details, but I just cut the R32 ones and used size-changing joiners to connect them to the appropriate points on the back end of the inlet manifold/water log stuff.  The R32/RB20 stuff is different sized to the R34/Neo hoses, so you can't just get Neo hoses and use them (and they go to the wrong spot on the firewall anyway, I think).
This is the list of numbers I used for replacing all of the rubber hoses in my engine bay, I added some metal pipes in there too, you can ignore those.
I used this website/diagram to get part codes/numbers
http://www.jp-carparts.com/nissan/partlist.php?maker=nissan&type=81&cartype=12&fig=211
Hope this helps!
  • Thanks 1
First image is original R32 heater hoses coming out of firewall and going behind head.  Note that the RB25DET Neo steel heater pipes have been removed from the back of the head.  (Ignore the small hose mixed up with it - it's my current attempt to stop smurf jizz spoogin all over my parking spots.
Second image is same R32 heater hoses seen from other side of head.  Retains the original R32 bleeder point (just under the brake pipe you can see on lower edge of photo).  If you look down next to the clutch master, where the brake pipe bends under it, you can see the hose clamps that show where I have the size reducing joiners.  I cut the R32 hoses here, put the joiners in and also cut back the RB25 hoses coming off the head/water log/block (wherever they each came from).
The last photo shows same thing from forward of the clutch master.  The bit of heater hose with the dried green smurf spoof is the RB25 heater hose and you can see its hose clamp onto the engine side connection behind that bit of loom.
14 minutes ago, GeeDog said:
Did you get this sorted? I've found the body side heater hoses off my R33, and I'm in Adelaide. They are 19mm / 3/4" ID, and appear to be in good condition. Removed cause track car.
I went away so this is still a future me problem.
  • Haha 1
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
