Hi all, recently got a new set of wheels for my r33, 18x8.0+30 for the front and 18x9.5+35 for the rears, when shopping around these are the exact sizes two places recommend me for wheels also recommending 265s on the back, but after sorting a set of wheels with 265s for the rear and taking them to get fitted, the guy there says he won’t be able to fit them there too big, after putting them on they do seem to be rubbing the gaurd while stationary, but he says even raising it and rolling the guards it won’t fit, I was wondering how I would be able to get them too fit as these where the tyres recommended too me and after looking online a lot of people have been able to fit 265s and bigger on an r33
https://www.sau.com.au/forums/topic/473403-fitting-265s-on-r33/
It's all about the offset.  You can buy spacers to push wheels further out, but you can't buy unspacers to bring them further in.  If the tyres are rubbing on the outer guard, then you're shit out of luck.  Different wheels required.
You do realise that there's a whole thread devoted to what wheel and tyre combos fit on Skylines at the top of this very forum, yes?  Read, see what works.
Edited by GTSBoy
The only way to get more clearance is to run more negative camber on the rear. I would roll the guards first and then dial in neg camber until they clear. You'll most probably need rear upper camber arms too. Neg camber will also create uneven tyre wear.
Put up a pic of how it's sitting, so we can see how bad it is.
Ultimately as said above a different rim will fix your issue but i would have thought that combo would clear. I run an 18 x 9 +22, this would sit almost the same as yours in relation to the outer edge and i fit 265 under rolled guards ok. On the latest set i put on (AD08R), they run a bit wider. I had to increase neg camber to -2 deg.
Incorrect (excessive) camber will result in poor traction and handling, and silly tyre wear.  Suggest about -0.5 to -.0.75 is where the aimpoint should be.
Another clearance fix is to get handy with angle grinder, tin snips, hammer, and welder.  Cut the guards, install flares.  Instant clearance.  And depending on your viewpoint, they look good too.
Unfortunately don’t have any pics of the fitment but it’s pretty close to flush. What sort of ride height are you at because mine is quiet low, I suggested raising it up a bit and then cambering the rears but he’s still under the impression that it’ll hit badly and probably damage the fenders
Mine isn't very low, around 330mm from rim centre to bottom of wheel arch.
Since you already have the wheels and tyres, get the guards rolled and take it from there.
Another option would be to go to a smaller tyre, say a 245. It's not something i would really recommend but if you can't make them fit, its an option.
Depending on the rims, you also have the option to get the hub mating surface machined. There are businesses who specialise in rim repairs, who can do this for you. There is a minimum thickness they will machine to, so the rims may or may not be suitable. I had 4mm removed from 2 front BMW rims recently to fix a rubbing issue - cost was around $80 per rim.
I think the offset you needed on the back was +32. I have the same size wheels with 265's on mine and fit fine. I rolled my guards because i had to do the fronts anyway and have normal camber rates
Trying to share photo but I cant on my phone for some reason
You could always stretch smaller tyres on?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
