Hi Guys,
Selling my Apexi Power FC for the R34 GTT (Manual Models Only)  Pretty sure these work for the rb25 neo stageas too.
Perfect condition plug and play computer.  Any decent tuner workshop will know this computer inside out.
Comes with the new, rare and expensive EL (Organic Display) Hand Controller.
I recommend you check out this fantastic site for all power fc details.  click here
What you see in the pics is what you get.
Located in Sydney but will post nation wide.
$750 postage included.  Firm
PM me.
  • Like 1
  • 5 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
