S1 key barrel removal?
KeniKat
 Share
Hi everyone,
I need to get the key barrel repaired on my s1, has anyone else pulled theirs out and would they have any advice? in doing searches i can find loose instructions for r34 but not c34, is it the same?
thanks in advance
keni
Drop steering column to lowest point.
Remove steering column shroud.
Tap or drill a groove big enough to be able to get a small chisel or screwdriver etc into and use a hammer to tap it anti clockwise, should loosen up after 1 whole rotation. "Crack" both of them first and then loosen rather than undoing one all the way and then cracking the second one.
The stud/bolt things will most likely be trashed after removing them especially if it's your first go at changing one - I've used these as replacements on other Nissans before: https://www.ebay.com.au/itm/NEW-OEM-NISSAN-IGNITION-LOCK-SECURITY-BREAK-AWAY-BOLTS-FITS-MANY-MODEL-NISSANS/272732154680?fits=Make%3ANissan&epid=1111287003&hash=item3f801a6b38:g:DVQAAOxyPc5R7tRd
Haven't used the above before on a Stagea before but have done Skylines/Maximas/Pulsars etc
The rest is just the reverse to put it all back together.
  • Like 1
 Share
