Im trying to fit an analogue cruise control kit to my 07 V36
Does anyone know where to find an analogue speed sensor wire for an 07 V36?
I've searched high and low through many g35/g37/j50 FSM and cant find any wiring remotely close to the JDM Skyline cars.
I've also searched on here to no avail.
Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/
If you put cruise control into the search box you will find a couple of Stagea owners have done it on their NM35s - ok not a V36 but still drive by wire...
  • Like 1
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7871896
When I mention I've searched the above FSM, they all show a red speed wire going to pin 28 @ the a/c amp/unified meter, (for the trip computer data) but my(our JDM) cars dont have the same wire in the same spot, which I was hoping if anyone else had come across this and solved this problem.
Yes I know of this, I have done this in my Stagea, and now wish to do the same in my V36.
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7872022
  • 3 weeks later...
I know I'm a bit late to this party but since people have been nice enough to help me out with a question earlier this week, I thought I'd contribute to this one.
Not sure if you've had any luck since but most certainly one of those wires going to the A/C and Instrumentation Amplifier will be your speed sensor. The only way to be truly sure though is to grab an oscilloscope and measure the waveform. I haven't got the FSM handy on my laptop but when stationary, the signal should either be constantly high or low and when in motion, you should see a pulse train that increases in frequency proportional to speed (you'd need to have the rear wheels up in the air or on a roller dyno of sorts to confirm this though). Basically, the pulses should start to pack together closer as speed increases.
That's how you'd find it without any reliable documentation. It's similar to the park brake wire (also going to the same unit) I had to find for a device I built, where it wasn't in the place the FSM indicated, so I had to sniff it out with a multimeter and see which one changed between active low and high.
  • Like 1
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7873851
I haven't had much luck yet; Been a bit slack and a bit nervous probing back there even though I do have some US FSM.  I was even given a probe extender (a wire with a sharp point on one end) so it would make the job easier.  I just have to get the courage to get in there and test it for myself.
https://www.sau.com.au/forums/topic/473711-v36-speed-wire/#findComment-7874915
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
