There's a million things that could be wrong.  Start by assessing whether there is even power to the back of the air-con computer.  Progress to seeing if there is enough gas in the system to satisfy the pressure switch.  You will almost certainly need to take it to an air-con mechanic at that point.
You will need a air-con mechanic to hook up their gauges to your AC lines to check that.
Check the controller in the dash is getting power, if at all possible swap it out for a known working module and see if that fixes the issue. If the fans don't turn on at all I would lean toward it being an electrical/control module issue.
Yuh, the refrigerant pressure switch will prevent the compressor from pulling in to prevent you operating an empty compressor.
Other things that can stop the air con include that even the fan circuit could be dead (fuse maybe) and if the fan won't run then you don't get a permissive to run the compressor (so you don't ice up the evaporator). There's a bunch of things.
If you aren't good with cars, check the fuses, follow the advice above, then take it to an air-con guy if you can't see something simple holding it out.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
