16 hours ago, GTSBoy said:
Shafts are piss easy.  Fall out from the inside.  Hubs/splines are obviously much more trouble.  You need to dismantle all this to find out what is wrong with it before you go buying stuff though.
Ok cool figers crossed its just the shafts.
3 hours ago, hardsteppa said:
Having had  the same movement, i rebuilt the cv's, replaced bearings, new bushes, new diff centre with perfect backlash...i still have the same movement.  However..images.jpeg.8136256e0d9e64410795ed90d9daa444.jpeg
For real?  hope i dont play that game
I learnt from gts boy and stepper and did sfa and noticed no difference. Car drives fine with that type of movement, even at 240+ km/h. My advice is leave it alone unless the wheel is going in/out from bearing wear, that would require attention.
ok now watched the video...looked normal to me. Diffs don't have zero backlash, they have a small amount for a very good reason, which is visible as a bit of turn in the driveshaft like that, when not under load.
the 5 bolt driveshafts on the r33 gtst use a 5-ball cv joint in both the inner and outer, which for most purposes is as strong as fk, there's nothing in there to ' break' really, only wear a groove at best, unlike the 3x2 bolt shafts which I believe use a 3x ball bearing race on the inner. I rebuilt a spare set of shafts and they had exactly the same movementousness as my old ones, which when pulled apart had no visible wear.
What I am getting at is if you're not having any ' issue' as such, the bit of movement like that is unlikely to be any concern.
Ok maybe It's nothing, there's no bearing movement. Drives normal only thing i can think of is I get an odd click when taking off sometimes was thinking that could be related. Not continuous just once.
Here's a vid of it, car jacked up in neutral handbrake on.
 P1370539_2.mp4
Handbrake off in gear.
 P1370541_1_1.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
