Hello, so i have my aftermarket coolant gauge wired to an sensor in the upper hose, the 2 wires can be seen going into the sensor, but I want  to use the existing port that is for the stock coolant gauge. The problem is there are 2 wires going to the sensor i have now in the upper hose, but only 1 going into the stock location where i want to wire my aftermarket gauge too. What do I have to do to wire it? I dont think the stock sensor is a 1/8th npt size either? (pictures below)
Thanks for any help
IMG_0950.thumb.jpg.e037045f9a66ce8ec51e9335c43db0a9.jpgIMG_0951.thumb.jpg.58a1612b0ed308eb097ecd9d374d6a2d.jpgIMG_0952.thumb.jpg.f86cea644009dfd035f08f4ed572beae.jpg
11 hours ago, GTSBoy said:
Aaahhhh....take the single wire temp sensor out at your great peril and misfortune.  That one is for the ECU.  The 2 wire runs the dash gauge.
Ohh , I was told the single was for the gauge! Thanks for the clarification
Now I could be wrong, but I would have bet 5 bucks the single wire is the gauge sensor.
Based on this train of thought :
old cars had single wire for gauge, then efi came along and there were 2 sensors. I just assumed single is still for gauge. If I am right I am owed 5 bucks. Ig wrong the bet never officially took place.
  • Haha 1
Yea I thought it was the single too, that’s what someone else said too... that’s why I’m confused on the wiring
1 hour ago, smart_garrett said:
Ok, so can I just ground one wire from the new sensor and splice the other one into the old sensor?
I'm not sure as I haven't installed an aftermarket sensor. I guess you could try it. Do you have a separate temp gauge (in case the stocker ones dies)?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
