Hey all,
Thought i had a build thread for my 32 but cant see it so maybe not, anyway.
Bought (becuase it was cheapppp) what can only be described as the worst looking r32 around. Ugly kit, check. Ugly white painted interior, check. $2 bucket seat, check. on LPG, yes LPG! check.
i wanted a project, so i bought it for cheap and brought it home
  • Like 1
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/
Since i killed the front bar, i found a GTR front bar and lip
Plus for now also got a standard r32 bonnet
Also removed everything to do with the LPG, thankfully it wasnt dedicated LPG. Just had to remove, fill a few holes here and there and bingo
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877417
a pair of excellent nic 32 gtr seats came up for cheap so replaced the crappy $2 recliners in it.
Plus started to remove anything painted white inside the car! and also changed the steering wheel to one i had lying around
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877419
The rb20 still runs fine, so removed to give it a bit of a tidy up and new gaskets etc etc. not looking for this car to be a power house, always wanted something that looks nice when you pop the hood. plus i already have my track car for speed.
So while the engine is out im tiding up the engine bay. removing all the HICAS, Putting the Battery in the boot, and hiding the fuse box. Will also change a couple things like the washer bottle, over flow etc. Will then fill holes, smooth and paint
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877423
I had a look at the Pandom kit for the 32 and didnt like it... so instead i did a thing.
I bought genuine rocket bunny flares front and back, same as the car below, from streeter.
Now not 100% sure ill go this way but they are sitting there
  • Like 3
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877426
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
