R33 GTST Gearbox and Nismo Super Coppermix Twinplate clutch kit
R33 GTST / RB25DET Gearbox from Nissan Skyline. Had in car ~6 months, had no issues whatsoever shifting, grinding, popping out of gear, exploding, etc etc etc but did only have few months. Removed as engine also removed from car.
Drives and sounds like any R33 GTST gearbox that I have personally ever seen.
Has new (nismo lol) pivot ball. New OEM slave cylinder too, and a non 18 year old dust boot and crossmember, and new gearbox mount.
Nismo Twin plate super coppermix clutch kit with lightened flywheel. Also near new, driven about 10,000kms. These things last many many years of abuse, never received really any abuse as engine/gearbox now out of car. Will hold 450 rwkw, and drive like a clutch that won't make you hate life and can drive daily EASILY
$3000 for both, will be $3200 if you make me seperate them.
Located Glen Waverley, Melbourne.
  • Like 1
https://www.sau.com.au/forums/topic/474214-parts/
Set of 6 Delphi/Xspurt Ethanol injectors for a RB25DET Neo (originally purchased new from Scotty)
Comes with Fuel rail!
Comes with injector loom and plugs, pre-plugged and ready to go!
Comes with Apexi adjustable fuel pressure regulator!
Never had any issues, injectors are MADE for E85 as opposed to being "E85 Compatible". Injectors will still happily run 98 as well, and were doing so most recently.
https://www.sau.com.au/forums/topic/474214-parts/#findComment-7877491
So you want a high mount turbo and 400KW. Stop looking at turbos and buy this. You're going to need all of it to get going anyway. You're going to need to get shit fabricated. Buy this instead. Save your time and money.
Kit includes:
1x Borg Warner EFR 7670 1.05 T4 Twinscroll Turbo
1x 6boost T4 Twinscroll manifold, ceramic coated black
1x 50mm Genuine Turbosmart External wastegate
1x Set of Braided lines from the boost solenoid (built in!) to the external gate. Already plumbed up correctly so you don't have to get confused.
1x Dump pipe, front pipe, and Cat, with provisions for a Wideband O2 Sensor in a sensible location so it doesn't fkin die in 3 months.
1x Screamer pipe, running well under the car. You could join these to plumb them back easily. I did.
1x Set of Speedflow lines and fittings. Don't buy a cheap kit. Don't buy a cheap kit. Don't buy a cheap kit. DON'T BUY A CHEAP LINES KIT. I almost melted my car to the ground with a cheap lines kit. I then got this kit, which is all solidly mounted, away from things that melt or crack or will move under load. Don't buy a cheap lines kit.
1x Pod filter, and metal intake.
1x Pre-Loved Blitz SE Intercooler which requires no cutting and uses stock holes in the chassis for piping.
1x Turbine outlet pipe to intercooler, and charge pipe to throttle with provisions for Air temp, stock power steering nipple
Comes with all the joiners and hose clamps and fkin bolts and random bits of crap you would otherwise be running to Autobarn for and trying to make fit.
Remove OEM turbo side. Bolt everything here onto your RB25. Enjoy the best turbo money can buy. Just add fuel and ECU Smarts.
Yes it all does work, no, the piping doesn't cause lag, no the intercooler flows this more than fine. No you don't need more power, you'll blow up your motor, or have too much lag, or have no grip.
Do the math, then buy this and be happy with your life choices! No more thinking about how you'll make it work. This works.
ps, yes the flex joint is beat up a bit. No, it doesn't leak, seriously ?
  • Like 1
https://www.sau.com.au/forums/topic/474214-parts/#findComment-7877492
Splitfire Coilpacks for RB25DET Neo.
Part (DIS-008)
Comes with near-new coilpack loom purchased a recently.
Coilpacks themselves are ~3 months old. Selling because sold the motor that they were in. Work perfectly, still have the box in good condition too if you're interested in that kind of thing.
Located in Glen Waverley, Melbourne
https://www.sau.com.au/forums/topic/474214-parts/#findComment-7877494
fuark. Thanks admins for merging all my intended to be seperate threads.
Whether I forgot to put prices on them I am unsure as they were all copied and pasted from Gumtree.
Prices:
Injectors + Fuel Rail + Apexi FPR + Injector loom/plugs = 600
Coilpacks + Coilpack loom = $450
EFR Kit = $4999
Gearbox and Clutch = $3000
Edited by Kinkstaah
I am bad at internets.
https://www.sau.com.au/forums/topic/474214-parts/#findComment-7877551
Prices:
EFR Kit = $4999
Coil pack & loom still available?
https://www.sau.com.au/forums/topic/474214-parts/#findComment-7878444
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
