Hi Guys, this is my very first post on this forum so sorry in advance if this doesn't belong here.
Alright to get started. For the past year now I've been having issue with my 1999 Nissan Skyline R34 25 GTT.
I've took it to numerous mechanics and still to this day none of them knows the main problem.
The problem is , when i'm driving my car would shit it's self and turn off ( even if i'm doing 70km) First signs before it turns off are loss of power during revs, then all the dashboard lights comes on and i lose my power steering.   Even sometimes when i'm at idle it would turn off , and or when coming to a complete stop it'll drop revs and turn off. Now lately it's been turning back on after it stalls after a few cranks, Where other times it won't turn on at all and i have to get it towed. ( had it towed 8 times in the course of 2 months). Then i buy a new fuel pump and it works fine again for another couple of weeks then dies again. I've brought over 6 fuels pumps and still have this issue. SO far my car ran fine for 2 months before it happened again today and it's un driveabale.
I've changed the Cam angle sensor
clean the pod filter
-Brand new coilpacks/ sparkplugs. Brand new fuel system( new fuel pump, fuel filter, regulator, wire-ring hatch)
- New vacuum hose.
I took it then to an auto electrician and he said it was fine that he couldn't find any electrical problems.
The only thing i can think of is new fuel injector's but multiple mechanics said that's the the cause.
I really in desperate help to fix this issue and it would be much appreciated if anyone could help :)
https://www.sau.com.au/forums/topic/474329-car-stalling/
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
