So I got my gtx3076 gen2 v band, I think .83 housing on v-band setup, 6 boost, turbosmart wastegate Installed. 1 bar base spring, it’s a pro-gate lite 50mm on a rb25neo, unopened
on mapping at base pressure it creeps to 1.35 bar. Is this a known trait of them ?
Had some boost control issues too so need to narrow it down to either the hks controller which is difficult to set, or possibly check that a grub screw has not fell out of one of the ports to block off unused 1/16th npt ports,
but if I get that sorted I aim to run 1.4 bar through the controller, is that likely to creep too or would that stabilise a bit in that I’m wanting to use that pressure rather than dump it?
i will get some details as I actually get time to go play with the car, left it at that on Friday and actually tuned the creep as a minimum but I want to have a regulated 1.4
Edited by Eager
https://www.sau.com.au/forums/topic/474334-gtx3076-gen2-boost-creep/
Got any pics of your gate + piping setup?  Gate takeoff angle and plumbing is a critical aspect to achieving proper control.
Graph showing how boost ramps and what control through the range without BC active would be useful.
Have you spoken with either the fabricator, or your turbo equipment supplier?
I have had a 6boost and 45mm and 50mm gate in the past, with a 3076, 7670 etc.
Never had creep, so not entirely sure what is going on there, but that setup should be able to hold a nice low boost if you want it to, it is certainly not 'normal'
What kind of ECU do you have? You can probably get better boost control with the ecu controlling a Mac valve.
NB wastegate comes off turbo housing
See below - Link + Mac Valve + Synapse 50mm W/G
Quick pic I have of the exhaust side built up,
im thinking there should be a better angle to the wastegate joined on with a length of pipe? I aim to run 1.4 bar through the hks evc and hoping that may stabalis things, and bring the boost in harder
currently just on the wastegate as we couldn sort the boost controller but I will sort that and it’s a hks evc 6 controller, on a power fc
Open to all advise lads, thanks
Greg for interest/comparison, do you have pics of your gate setup?  This may help with conversation here.
A lot of effort went into my 6boost gate takeoff angle but we found measured/logged boost pressure around 6 pounds higher than the rated (and bench tested) weight of the gate spring (50mm Pro Gate).  Boost was steady/consistent, just higher than we expected.  Solution was to run a lighter spring than what the actual target is.  Pragmatic but effective; and lots cheaper than more fabrication work.
From my for sale thread:
I had the default spring in the 50mm gate, but mine was a progate as opposed to a progate lite, so it was holding about ~9-10psi on gate pressure with a 14psi spring in the thing, on a 2.8L Neo at the time.
I was going to one day up the spring pressure to compensate but 18psi was 400kw at the time so I honestly never really needed to go more, but control at over 18psi was starting to get really wonky with a 9-10psi base spring pressure.
I wasn't really happy with the angle either. Its a T4 TS manifold with an undivided gate. The previous 45mm gate was on the turbine housing done by Scotty here. I was able to run as little as 4psi through that (and up to 25psi with a 4 port). Coming from that, the 6boost felt terrible, but honestly functioned really quite fine in the real world.
I agree - mine is functional too,  just found it annoying that it the observed boost level so out of whack with the spring rate.
Probably fair to say that with the engine/turbo combinations we really aren't legitimately targeting 1 bar boost though.
As per Johnny's comments, you need to make 100% sure the boost control plumbing is correctly hooked up.
That boost graph scale is terrible, but trend seems to be creeping from 3800-4800.  That's where your controller should be doing its thing and bringing up boost (and torque) in that range.
That said, how's it drive right now - does it put power to the ground through that range, or turn tyres?
Hi chaps
so tonight I got the exhaust vband released from the turbo and plugged a port on the wastegate, that was meant to be plugged with a 1/16th bung. So up until now I’ve actually just had the controller turned off
however, I’ll now attempt to set the controller over the next few evenings. As for driving, it drives nice, a touch laggy but unless provoked it puts all power to the ground without breaking traction.
I get what your saying and that’s a fair point? Run a lower rated spring and use the controller to bring it up to 1.4. That may prove to be more steady
i looked at how the wastegate is mounted to the manifold, there isn’t a lot of room on there for a install that allows a more ideal mounting with easier gas flows
To add, I’ll describe my boost control lines if one of you could maybe confirm for me I’m correct ?
its a hks evc 6
on the solenoid, looking down on it, barbs out the top
Right barb, goes to inlet manifold
centre barb reads pressure from nipple on intercooler pipe, also T’d over to stock map sensor and To middle port on wastegate
left barb, goes to end port on wastegate
included a pic of the manual and solenoid as described above
Can see here the grub screw was missing
now replaced the missing bung
look ok lads?
Edited by Eager
It comes down to what you want to achieve with this setup. For me, traction is king.  Some want maximum mid range punch and enjoy the struggle to master throttle/skid control even on dry roads.
My particular setup allows for more/less boost via a dashboard knob, for driveability in various track conditions. (relatively easy process with an ECU that's newer/more advanced than the Power FC).
In your case, I think what you could try is to get that boost controller functioning, and have the boost come up to the targeted value earlier across that 3800-4800 rpm band.  Given that your target is 1.4 bar, and you're getting 1.35 bar from a 1 bar spring, it's probably fit for purpose.
End of the day, a rock steady flat boost curve might look good on a graph, but not give the desired driving experience. It's down to your preference. But play with the controller and see what you like from the result.
It’s a grip car so that’s what I’m after, and I’m guessing that progressive way the boost does come in helps that too,
I’ll try get the controller running. Does my plumbing make sense ?
1.4 is my target on 97 Ron fuel but if it seems reliable I’ll possibly try 1.5, i don’t want to forge the engine however so baby steps I guess. What’s the opinion ? On a safe level for a unopened neo
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
