Hey guys, been trawling through every forum trying to find diagrams and pictures to help with wiring an auto to manual conversion for my R34 GTT. Have done everything apart from wiring. I have read a thread but had no pictures. Think I've done all the gearbox wiring correctly, however, struggling to find the inhibitor switch. Anyone who's done this should be able to help me? Some are saying inhibitor switch is by the fuse box but still unsure?
Thanks in advance.
https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/
Got the inhibitor switch working.
Id have to get photos a bit later. There’s a brown and black plug from the auto box speed sensor. Not sure which one to use. And then a black and green sensor from th PNP switch. Green isn’t used. The black one you use red wire and a ground wire from the speedo sensor for the reverse. Just need some photos to follow really.
Nope.. Tried both auto speedo connectors and tried both wires and tried them opposite ways and nothing which is quite annoying! Your reverse wires were spot on though cheers! Might have to get it finished off by an auto elec, unless you got photos or something?
I remember vaguely (months ago) when I did this, I initially hooked the R33 GTST speed sensor into the wiring loom for the wrong auto speed sensor, as you have described the R34 GTT auto loom has wiring for two sensors as the auto has two "speed sensors".
Unfortunately I'm in no position to get under my car and check it out, but I do remember getting it backwards and going 'aha' upon consulting both diagrams (i.e manual gtst box and R34 GTT)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
