So the other day I took my 34 gtt to work, it’s running a 3076 6 boost power F.C. and z32 etc etc, got to work fine which was a 8 mile basic commute with the last mile a poor road surface
anyway came out of work to drive home and noticed a miss or a bit lumpy, looked down at the wideband and it’s running 18 or so to 1. So very lean. From idle to cruise right through its lean
I went into the power commander fuel adjustment and dumped the fuel in up to 1.3 to get it running smoothly and back to about 15:1 and limped the car home
so first investigation was car seemed low on fuel so chucked a can in, in case it was to low,
also inspected some hoses and noticed the pipe on my z32 afm to turbo was not sealed perfect, it wasn’t off much but I squared it up and tightened it anyway, started the car and it seemed spot on so assumed it was fixed, 15 minute test drive and all was fine so put the car back in the garage
Went to take it a run tonight and reversed it out of the garage and it’s lean again, at idle and through revs do just put it back in the garage,
any pointers ?
its a fairly recent top mount turbo install and map, 300zx fuel filter and a new Walbro was fitted at map time 500-700 mile ago just. Injectors are r35 gtr and also low miles. Voltage still regulates for pump so would like that hard wired,
I want to swap a different z32 in too just to rule it out but any other ideas ?
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/
Oh I know, it was just to get me home, but even I richened it up there was no missfire present
but certainly no missfire is evident, and on the 15 minute test drive the other night it ran perfect. With power F.C. on its map just, no adjustment, I thought the pipe adjustment sorted it as it ran perfect
At idle there tonight it’s stable just lean, not missing
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7882524
Ok
so ive had another look around the engine bay and noticed there is a loom that runs along the suspension strut area, off it comes a few things like the o2 sensor, stock boost solenoid plug, it runs over to the afm and then into the wing, maybe headlight?
it seems a bit charred, it’s not completely burnt but certainly has had some heat from the top mount install running fairly close
can anyone tell me is that part of the main loom or is that a piece I could replace easily ?
It might not be at fault but it doesn’t look great
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7882556
Sooo done a quick compression check. She isn’t good boys lol.
What’s the official number order by the way?
1 being at radiator, in this case below, 6 at bulk head
Results on cold engine
140-150 odd on 1,2,4,5
3 gets to 140/145 but takes a few extra cranks. 6 is 60 or so and jumped to 70 odd with a little oil in the cylinder.
Going to do a leak down test and bore scope next to decide what is leaking. But the car runs fine, revs fine and has no misfire or nasty noises once the fuel is adjusted on the hand commander.
Edited by Eager
https://www.sau.com.au/forums/topic/474640-running-issues/#findComment-7883451
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
