Hi all, has anyone experienced fuel gauge issues below a quarter of a tank?
Mine fluctuates wildly but seems to right itself after a bit of driving/sloshing but can drop as low as an 8th and turn the light on but then come back up to a quarter.
Annoyingly the DTE under the 'boost leaf' must get its readings from the same sensor as that fluctuates too.
Does this model still have a conventional float level sensor? Could it just be dirty contacts?
https://www.sau.com.au/forums/topic/474711-nm35-fuel-gauge-inaccuracy/
Ah, right. Thanks for the responses. Good to know I'm not the only one.
I did find a diagram of it and appears to just be the one sensor but sits on the opposite side of the fuel neck and pump/filter assembly. I suspected it would be similar to the WRX where it sits over the trans tunnel and essentially splits the tank but there's no secondary fuel pump from the looks.
If it makes you feel better (if schadenfreude is your thing), both my PNM35s did this as well. Was never a problem until the tanks were drained below the fuel light level, and they were all over the place after that. They read ok for the top half of the tank, but after that they'd fluctuate between half and near-empty.
To anyone reading this before this problem occurs to them, I'd recommend not running below 1/4 tank.
There was a post on g35 driver about cleaning the conacts that had shown some success. I asked if anyone else had tried it about a month ago on m35 tuners Facebook but didn’t get anything out of it.
https://g35driver.com/forums/media-share-g35-coupe-v35/425938-diy-fuel-sending-unit-fix.html
  • Like 1
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
