Hey guys, hope you’re all good.
I have an obnoxious sounding vacuum leak somewhere under my throttle body. It’s very bad and throws out the car terribly, so it’s off the road and I’m addressing ASAP. There is no issue around the TB itself and I don’t see any kind of issue around the fuel rail or injector seats, so I’m assuming it may actually be either the upper plenum gasket, the lower inlet manifold gasket, or perhaps an idle control hose underneath the manifold somewhere.
To the point of my thread - if I can not locate any obvious leak, I will be pulling off the intake to replace the gaskets. Should I get so far as to pulling off the lower intake, I was just wondering if anyone had tips or advice to share? Specifically regarding how and what to disconnect in regards to coolant hoses, vacuum hoses, etc, and if there are any tricks to any of the bolts?
Ive searched extensively on this topic but most threads only cover the upper plenum and I’m looking for any general helpful tips to removing the whole thing. So far my plan is to remove the TB, the fuel rail, then upper plenum - raise the front of the car up and just see what I can attack from the bottom. Assume that’s the best method?
Thanks in advance!
https://www.sau.com.au/forums/topic/474913-lower-intake-manifold-removal/
If you're going to replace the upper plenum gasket then you should definitely do the bottom one to. The bottom plenum is actually really straight forward. You just have to fight the awkward angles to get the bottom bolts off. Legit just did this whole job in 2 hours the other week. Take a lot of pictures. It was actually really hard for me to mess up, so don't worry about that. I attacked everything from the top. Never once did I go under the car. And btw, my car was making a god awful whistle noise too. Turned out to be the gaskets. Let me know if I can send you any pictures or anything.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
