Missileman Posted October 12, 2018 Share Posted October 12, 2018 As the weather is warming up I've noticed that my 32gtst is not starting from cold as easily as it does or should compared to winter time, we just had a really cool morning and the car started first crank, when the engine is at operating temp restarting is fine, always first crank, it just has an issues starting first start of the day when ambient temps are over 25c Any suggestions before I start playing around in nistune? Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/ Share on other sites More sharing options...
burn4005 Posted October 12, 2018 Share Posted October 12, 2018 Probably need more crank prime at warmer areas 1 Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887683 Share on other sites More sharing options...
GTSBoy Posted October 12, 2018 Share Posted October 12, 2018 It's actually probably the change in fuel from winter blend to summer blend. Tuning it out will possibly require reverting back in 6 months. Try it and find out. Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887699 Share on other sites More sharing options...
Missileman Posted October 12, 2018 Author Share Posted October 12, 2018 Fresh tank of fuel from a very new seven-11 noticed the same ting last summer, issue disappears in winter. I think it's running a little rich in the cold crank table, will have a play when it stops raining... Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887701 Share on other sites More sharing options...
89CAL Posted October 13, 2018 Share Posted October 13, 2018 Was it tuned in winter by chance? Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887725 Share on other sites More sharing options...
Robocop2310 Posted October 13, 2018 Share Posted October 13, 2018 I don’t think it’s the petrol that’s the problem. Suggest you check/clean coil packs and inspect spark plugs might need to replacing. Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887731 Share on other sites More sharing options...
Old Booster Posted October 13, 2018 Share Posted October 13, 2018 (edited) Take back to the tuner and get a touch up. Edited October 13, 2018 by Old Booster Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887735 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 14, 2018 Share Posted October 14, 2018 Your crank fueling vs temperature is out. Bring it back to your tuner or if you have Nistune fix it yourself or download it and send it to me and I'll fix it for you. 1 Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887782 Share on other sites More sharing options...
Missileman Posted October 14, 2018 Author Share Posted October 14, 2018 Tune was by me a couple of summers ago, thanks Johnny I'll open it it up and have a look, If I have problems I'll send you the file to have a look at. Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887801 Share on other sites More sharing options...
Missileman Posted October 15, 2018 Author Share Posted October 15, 2018 On 12/10/2018 at 11:21 AM, burn4005 said: Probably need more crank prime at warmer areas Expand After looking at the tables I think you are correct, I've added a couple of percentage in the 20c and 30c blocks of the cold crank enrichment table., have to wait until the ambient tenps warm up to see if it made any difference. Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887810 Share on other sites More sharing options...
Dose Pipe Sutututu Posted October 15, 2018 Share Posted October 15, 2018 the graph plot should be some what an exponential decay Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887813 Share on other sites More sharing options...
Missileman Posted December 5, 2018 Author Share Posted December 5, 2018 On 15/10/2018 at 12:45 AM, Missileman said: After looking at the tables I think you are correct, I've added a couple of percentage in the 20c and 30c blocks of the cold crank enrichment table., have to wait until the ambient tenps warm up to see if it made any difference. Expand Update: my correction to cold crank enrichment has worked... starts like and idles like a champ once again. So now I suppose I should start looking for any air leaks, but only when all the rubber is cold. 1 Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7893068 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 5, 2018 Share Posted December 5, 2018 Yay! Now do a burnout or buy my turbo setup ? Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7893076 Share on other sites More sharing options...
Missileman Posted December 5, 2018 Author Share Posted December 5, 2018 On 05/12/2018 at 6:51 AM, Dose Pipe Sutututu said: Yay! Now do a burnout or buy my turbo setup ? Expand funny guy, I own a 32 not a 33. besides, I have not updated my dif yet. Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7893080 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 5, 2018 Share Posted December 5, 2018 On 05/12/2018 at 7:09 AM, Missileman said: funny guy, I own a 32 not a 33. besides, I have not updated my dif yet. Expand Everything will fit minus the cat back, just need to mod the hangers and shorten it Link to comment https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7893101 Share on other sites More sharing options...
