Hey guys,
Photos below: Got this car from the auctions, grey import, has skyline printed all over but rego doesn't specify model, it's listed only as 2002 Nissan sedan so I'm not sure what model I should be looking at for parts etc. It's obviously been modified by previous owner, suspension has been lowered, possibly chopped, don't know for sure. Local mechanic sent me this photo after I took it in for a service and told me the front suspension (mainly bushes) are destroyed, and the steering column is about to fall off...
He's said it'll take 6 weeks to source bushes/bushings for repair from Nissan, but doesn't seem sure about what parts will suit...
Any advice on what model's parts will be compatible and where to source them? Possibly quicker/cheaper? Or a recommendation for a more specialised mechanic?
Any help would be much appreciated, I'm at a loss!
Thanks
Just a V35 Skyline.  That's pretty much the only identifier you need to buy parts for it.  You can find everything you need for it on eBay, if you have to.  You can get rubber or poly bushes from aftermarket suppliers without any pain (apart from $$ - there will need to be a lot of $$ spent to buy all that you need).
That lower inner arm bush is so completely flogged.  I have never seen anything like it.  I hope you did not pay more than $1k for the car, because if the arsehat who used to own it has treated the chassis that badly, then the poor engine and tranny are likely to be 5 minutes from death.
If it were me, I would immediately dismantle it and sell the parts.  Probably safer than contemplate driving it!
Ouch, looks like you have a high mileage flogged car, hope you didn't pay much for it. You can replace all those bushes (you should, it's a safety hazard and not roadworthy), but you will have to spend quite a bit of money (think $1k+).
I'm fairly sure this bush is a common issue on V35s - I replaced them on my 350GT back in the day. You can get aftermarket ones from Superpro & other brands. Superpro list a SPF3298K as the Front Control Arm Lower Inner Bush, and they are $120 or so on Ebay (for a set that will do both sides). You probably need access to a press to remove the old one & fit the new one (or some patience), other than that it isn't a hard job. You would need a wheel alignment after replacing it. Obviously check the other bushes while you are under there.
Thanks for the info, actually found that same part number on ebay for about that price after searching for hours!
I'll see if my dad can do it, he's got a workshop, otherwise I suppose it'll have to go to the mechanic, he can check out the rest and give me a list of what else needs sorting out.
Tyre place right next door to mechanic so I'll definitely get the wheel alignment afterwards.
Yeah the suspension is pretty messed up, whoever owned it didn't lower it properly, I want to put a new suspension kit on asap. I've driven it for about a year on crappy roads too...otherwise it runs awesome, so I'm happy to put some money into it.
Cheers, yeah I'm not super pleased about how much it'll cost to sort out.
Yeah the mechanic was shocked, it was good timing...had just started feeling jolts over bumps etc. I think it's only so messed up because of the crappy home job suspension, which will be the next project...haven't had any dramas at all with the engine or transmission, not even a hiccup, otherwise I wouldn't even consider doing anything with it.
Yeah, it's parked up, won't be going anywhere until it's safe.
22 minutes ago, GTSBoy said:
Nah, chopped springs and worn out dampers won't really accelerate the wear on major bushes.  They just die because they're soggy, boggy OEM elastomer things that are only supposed to last 5 years.
Ah ok cool, hopefully once I replace them they'll last for that long again at least ?
The ones I'm getting are Superpro polyurethane, hopefully they'll be alright.
I do want more height though, I can't get down the angle into my carport lol
You have owned it for a year and don't know what it is?
  • Like 1
Bushings ordered and on their way, fingers crossed they're the right fit. Looking like I might have to have a go replacing them myself, with some help from co-workers and youtube lol. I'm super keen just to get under the car and see what it looks like...I'll post pics when I do and you guys can play where's wally with what else looks like it's about to break/explode/fall off if you like ??
Rawr!
Oh might just add...another minor issue, one of my bonnet brackets is bent/warped, can I get a replacement or could I bash it back into shape without destroying it because it's obviously weak enough that it's buckled ?
Thanks ?
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
