I had my apexi N1 coils (99 spec) repaired last winter by ohlins specialist. Cant remember exactly what he did, but all the shocks had leaked and now they seem to do ok.
Ride is a bit hard for a road car though, iirc the springs were around 10/9kg or something like that. Shocks are now at mid stiffness (15 or 16 klicks, goes to 32). Been wondering if I could/should get a bit softer set of springs and which ones to get. Atleast rhdjapan seems to sell lots of generic springs that should fit
On 10/23/2018 at 10:54 PM, niZmO_Man said:
Yeah Fortune is equiv to MCA imo
You can also get KYB/Koni/Bilstein + springs (probably easier to get it from Japan).
Are these spring rates comfortable enough for in town or highway roads as well without breaking my tailbone on road imperfections.
Contact the guy, tell them you want comfortable street suspension. If they can't help you, look elsewhere.
You don't want high spring rates unless they're valved really well, you want something a low lower like 6/4 or get standard/Nismo suspension.
Or just get BC coilovers
Link to Nismo S-Tune suspension: https://www.rhdjapan.com/nismo-s-tune-suspension-system-kit-r32.html
This is what I got for bc racing coils. What do they mean by “extreme low”? The height in my car now is pretty damn low with what I believe are the apexi coils
I recently installed a set of 8/6kg BC Golds in my 33 and I'm happy with them. Good quality for the price, when set up right they handle really nicely as well as retain a decent level of ride quality, albeit pretty firm its not crashy. I daily drive 120km each day on bumpy secondary roads. MCA would have been nice but would have cost around 2x as much to get here in NZ.
51 minutes ago, SeanR32GtSt said:
As it currently sits. I measured 23 inches from fender to ground.
f**king inches!
Measure from the guard lip directly above the centre of the wheel down to the centre of the hub cap.  Wants to be about 345mm.  What you have looks to be too low (for good handling, and for clearing speed humps, drains, etc).
20 minutes ago, GTSBoy said:
f**king inches!
Lol sorry mate. Here in the states we tend to be all “anti conformity “ with the rest of the world lol. But this current height does wel with our speed bumps. I don’t have to go sideways or nothing. Just go at it at no more than 10km. I’ll take another measuring pic when I get home tonight from school.
How low does your car sit?
As low as I could get it without the guards resting on the front wheels when you turn them. A little lower than in that pic as it has settled since then. I had to modify the front inner guards, tuck the wiring loom up higher, roll all 4 guards and fit extra bump stops to the rear to stop the wheels hitting the body under full bump.
That looks good. Sits about as low as mine. My BBS wheels are 17” so it gives the more low illusion I think.
Nice, yours is looking good too. Yeah its easier to get the car lower to the ground on 17"s, Im running 235/40r18 so its quite a large tyre.
Getting the heights is actually pretty fussy. When I got my BC's the body length was adjusted pretty close to right to allow the maximum amount of suspension travel without the tyre contacting body anywhere. So you should be able to just install them as is and they will be decent. But if you want to go lower that's when you have to make some careful adjustments, then drive the car to let the springs settle a little and adjust from there. Took me ages to get all 4 corners even and at the height I wanted. Then I had to add spacers on the rear shocks to limit the shock travel while still retaining captive springs.
Sounds fussy. I got a mate that lives bout 10km from me with access to a lift. Our game plan is to match the current coils with the new ones. Set the dampers to middle point of soft and hard. Lower the car off the lift and check the height. Then drive for a minute to check tyre rub. If not equivalent to what the car ride height was before we will lower it some more and repeat the same process.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
