Yes.  But what you have in your bay does not match the manual.  The line you are holding IS going between the canister and a solenoid, but the solenoid is behind the PS reservoir, which would tend to suggest that it is the boost control solenoid valve, not the purge solenoid valve.  Just follow the lines in the last image I posted and you will see what is supposed to connected to where.  I can't show you a completely useful photo of mine, because it is in an R32 and the canister is different.
  • Thanks 1
Thanks a munch for your help mate. Yes your correct, it was auto but has been manual converted recently. I have been having boost power issues since the conversion, the boost just seems to drop out after 4k rpms and only kicks in around 3k rpms. Sorry to complicate things mate but im trying to find anything that is related and im thinking this might be
47 minutes ago, GTSBoy said:
That's the boost control solenoid.
I have an electric boost controller and may have mistaken it but doesn’t this line hook up to a manual boost controller on some cars?
Edited by Robocop2310
The OEM boost control solenoid is hooked up to vent some of the boost signal from the compressor outlet tapping port on its way to the wastegate actuator.  the instant you put in any other sort of boost controller (manual, EBC, whatever), the original solenoid is no longer used.  The new boost controller then does what the original one used to do.
  • Thanks 2
Ok thanks mate, i dont have a manual boost controller so do you think this is why i am having boost issues?
1 minute ago, GTSBoy said:
It's in the last picture I posted.
I cant tell where there going to in the diagram. It looks like it goes to something on kr near the pipe but i cant see anything like that in my engine bay. Also i have this t piece here, is that normal or are those lines meant to go to the solenoid?
You won't find anyone who can show you a photo of a stock setup, because no-one has a stock setup.
So, if you look at the last diagram, you will see where hoses are supposed to sit, and if you look at the first diagram, and follow the pipes between the solenoid, turbo outlet and turbo inlet, you should be able to work it out, including the T piece.
  • Thanks 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
